8810 Temperature setpoint
  • 8810 Temperature setpoint
    When using this plugin with the 8810 it seems to skip 73 degrees on the homeseer side. When using the temperature + or - for the heating setpoint it will go from 72 to 74 in homeseer but end up on 73 on the thermostat. I've went up or down several degrees from 68-75 and 73 is the only one that seems to do this. This isn't a big deal as I never go above 72 on that tstat anyways-just an FYI. I did verify that my network wasn't the issue .
    There is also some weirdness with the indoor temperature device. The indoor temperature doesn't change a whole lot but it seemed to get stuck at 72 until I lowered the temp set point enough to where it would drop the room a couple of degrees. I don't know if that is the same kind of issue or if it is a different issue altogether. I can gather and send whatever you want for log files.
      Any chance you can circle back to this one? My 8840 has the same issue with 73 degree in temp setpoint or outdoor temp and it is a bit of an annoyance.
        The problem is that internally the thermostat use celsius degrees, so the plugin and thermostat have to convert back and forth from F to C
        the plugin uses the following formula:
        internal double ConvertCtoF(double degrees)
                    return Math.Round(((9.0 / 5.0) * degrees) + 32);
        whereas the thermostat uses a conversion table which is not strictly equivalent to the formula
        I will make the plugin use the same conversion table, and I guess that will fix this problem.
          Thank you, it is very much appreciated.
            Please test version 3.0.0.9, available in the Beta section of the updater.
              Seems to be working, thanks
