Request to add AUX HVAC Mode ?
  • Request to add AUX HVAC Mode ?
    Hey Spud, great plugin and thanks for the work you have already put into it.
    Regarding the request in the Beta testing thread, your post #69, you requested someone send you debug logs when in aux mode and didn't see a response, maybe it was a private message? Well, here are my AUX mode debug logs (attached) in case you didn't get to see them, looks like the only difference is this section:
    When in cooling mode:
    "settings": { "hvacMode": "cool",
    Then switched to Aux mode:
    "settings": { "hvacMode": "auxHeatOnly",
    Any chance you could add this to your plugin so we can display and measure usage ?
    If possible being able to set the device to Aux mode would also be great, currently I only have the following options:Heat, Cool, Auto & Off.
    Many thanks,
    Mike
    Hi Spud, any chance you would be able to add this mode to your plugin, i'm running out of trail mode and before purchasing it i would really appreciate knowing this functionality is possible or even in the pipeline.
    Many thanks,
    Mike
      sorry for the delay, I just posted version 3.0.0.20 here with "Aux Heat" HVAC mode.
      Please test and let me know. Thanks
        No problem at all, I will test and report back.
        Plugin purchased by the way !
        Thank you !
        Mike
          HVAC Aux mode status and action works great, thank you!
