Can't Install Plugin on Linux
    Whenever I install I get this error.
    Date/Time Pri Type/Error Message/Source
    Dec-09 2:06:38 PM Error Error, Creating plugin instance: HSPI_Ecobee.exe->Exception has been thrown by the target of an invocation.->Could not load type 'HSPI_Ecobee.EcobeeApp' from assembly 'HSPI_Ecobee, Version=3.0.0.20, Culture=neutral, PublicKeyToken=null'.
    Dec-09 2:06:38 PM Updater Install/Update of package Ecobee was successful.
    Dec-09 2:06:38 PM Updater Warning File exists, not overwriting: \opt\homeseer\Config\\Ecobee.ini
    Dec-09 2:06:38 PM Updater Extraction Complete.
    Dec-09 2:06:38 PM Updater Extracting files from zip file: images.zip
    Dec-09 2:06:38 PM Updater Copying file: \opt\homeseer\bin\Ecobee\System.Time.dll
    Dec-09 2:06:38 PM Updater Copying file: \opt\homeseer\bin\Ecobee\Ecobee.Net.dll
    Dec-09 2:06:38 PM Updater Copying file: \opt\homeseer\bin\Ecobee\Newtonsoft.Json.dll
    Dec-09 2:06:38 PM Updater Copying file: \opt\homeseer\HSPI_Ecobee.exe.config
    Dec-09 2:06:38 PM Updater Installing package Ecobee
    Dec-09 2:06:38 PM Updater Update HSPI_Ecobee.exe downloaded successfully
    Dec-09 2:06:37 PM Updater Downloading update: Ecobee
    Dec-09 2:06:37 PM Updater Starting download of updates
    Can you post your system profile using tools > help which may help to spot an issue. Also did you try restarting HS3 just to see if that helps?
    -Rupp
      MESSAGE BOARD (copy/paste section below to message board posts)
      Current Date/Time: 12/9/2017 3:05:08 PM
      HomeSeer Version: HS3 Pro Edition 3.0.0.368
      Linux version: Linux jarvis 4.13.0-16-generic #19-Ubuntu SMP Wed Oct 11 18:35:14 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux System Uptime: 0 Days 4 Hours 51 Minutes 56 Seconds
      IP Address: 10.0.1.3
      Number of Devices: 199
      Number of Events: 11
      Available Threads: 786
      Enabled Plug-Ins
      3.1.0.22: Sonos
      3.0.1.130: Z-Wave
      HELP DESK (copy/paste section below to help desk tickets & emails)
      License: Registered
      License: 108387
      User Name and Access Level: default (Admin)
      WAN IP Address: 72.49.195.167
      Web Server Port: 80
      Location: (Latitude) 39.341965 (Longitude) 71.03a-84.406761
      Enabled Plug-Ins
      3.1.0.22: Sonos
      3.0.1.130: Z-Wave
        Is it a SEL?
        If so, this is a known that is currently being worked on by HST, see this thread: https://forums.homeseer.com/showthread.php?t=191911
          No, It’s my own Ubuntu server
            ok, then try to install mono-complete
            sudo apt-get install mono-complete
