I have an event which informs me that Ecobee is offline according to Homeseer. I find that I quite often receive a message that the Ecobee is offline, and when I go to the thermostat, or login with the Ecobee app, I am able to access it. Today this happened numerous times - every 4 minutes, which I think is the default for monitoring. Suggestions on how to eliminate the false notifications? Thank you.
Ecobee Offline
The root device status can be set to Offline if the thermostat is actually Offline or if for some reason the plugin can't retrieve data from the Ecobee server when it tries to poll. So it doesn't necessarily mean that the thermostat is Offline.Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
My blog: http://www.domogeek.ca/blog/
TomGru, set up a device event that the device is the Ecobee thermostat, and is set to offline. I have it then text me via email that it is offline. But now going to add a counter that when it hits 15 - that would be one hour - of no communication with the Ecobee, lets me know so that I can check on it (I do occasionally have the Ecobee drop its WiFi connection).
When the Ecobee comes back online (to the app, anyway) I'll reset the counter to 0. Hopefully this will be a satisfactory way to monitor it.
Thanks for the info, Spud! Great app.
Originally posted by mdavison View PostTomGru, set up a device event that the device is the Ecobee thermostat, and is set to offline. I have it then text me via email that it is offline. But now going to add a counter that when it hits 15 - that would be one hour - of no communication with the Ecobee, lets me know so that I can check on it (I do occasionally have the Ecobee drop its WiFi connection).
I have 3 events.
One - IF EcobeeOnline value becomes this: 15
Then Send an Email to myname@myaddress
with the subject Ecobee Communication Lost
Two - IF Thermostats Ecobee Downstairs Ecobee had its value set to Offline
Then Increment counter EcobeeOnline
Three - IF Thermostats Ecobee Downstairs Ecobee had its value set to Online
AND IF EcobeeOnline value has exceeded this: 0
Then Send an Email to myname0@myaddress
with the subject Homeseer Ecobee Online
Then Reset counter EcobeeOnline (To Zero)
Make sure to run Three when you're set up to zero the counter the first time.
Originally posted by aldo View PostHi Spud, having the same issue, when I try to re authorize it and click on the button ecobee authorization, nothing happen while the log indicated thisThanks,Oct-27 3:50:47 PM Ecobee ERROR One or more errors occurred.
Aldo
related threads:
https://forums.homeseer.com/forum/th...-with-ecobee-3
https://forums.homeseer.com/forum/th...-was-cancelledPlugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
Originally posted by aldo View PostThanks Spud,that fixed the issue. Unfortunately all my thermostats still show offline, any other suggestion?
Please provide more information when you have a problem: OS, mono version, debug logs, etc..
