Ecobee Config=> Authorization
  • Ecobee Config=> Authorization
    I just installed HS3 on RPi 3 b+, running latest version of Raspian Stretch...
    I installed the Ecobee plugin, and when I click the config button, nothing happens... What exactly should be occuring when I click the config button...
    Here is my profile:
    Current Date/Time: 04/01/2018 20:46:20
    HomeSeer Version: HS3 Standard Edition 3.0.0.368
    Linux version: Linux raspberrypi 4.14.30-v7+ #1102 SMP Mon Mar 26 16:45:49 BST 2018 armv7l GNU/Linux System Uptime: 0 Days 0 Hours 3 Minutes 26 Seconds
    IP Address: 10.10.1.30
    Number of Devices: 39
    Number of Events: 0
    Available Threads: 388
    Enabled Plug-Ins
    3.0.0.22: Ecobee
    2.0.2.1: JowiHue
    1.5.0.0: MQTT
    3.0.0.31: Nest
    what do you have in the logs when you click the "Ecobee Authorization" button?
    did you move the Mono.CSharp.dll and CSScriptLibray.dll as explained in the user guide?
      Thanks... I did not move those, so will give a try when I get back to house. My apologies for not seeing those instructions earlier
        I moved the two files as requested, however, I still receive no response when I click the button...
        Here is the log output (I had debug mode checked)
        Apr-02 11:20:44	 	Ecobee	DEBUG No authorization. Please go to the config page to authorize
        Apr-02 11:18:41	 	Ecobee	DEBUG System.AggregateException: One or more errors occurred. ---> System.MissingFieldException: Field 'Mono.CSharp.CompilerSettings.WarningLevel' not found. at Microsoft.CSharp.RuntimeBinder.CSharpInvokeMemberBinder.FallbackInvokeMember (System.Dynamic.DynamicMetaObject target, System.Dynamic.DynamicMetaObject[] args, System.Dynamic.DynamicMetaObject errorSuggestion) [0x00006] in <7175e130f4634a60b0a49adbfc45babc>:0 at System.Dynamic.InvokeMemberBinder.FallbackInvokeMember (System.Dynamic.DynamicMetaObject target, System.Dynamic.DynamicMetaObject[] args) [0x00000] in <63992662b765477a898ef49cdcc99ee2>:0 at System.Dynamic.DynamicMetaObject.BindInvokeMember (System.Dynamic.InvokeMemberBinder binder, System.Dynamic.DynamicMetaObject[] args) [0x0000b] in <63992662b765477a898ef49cdcc99ee2>:0 at System.Dynamic.InvokeMemberBinder.Bind (System.Dynamic.DynamicMetaObject target, System.Dynamic.DynamicMetaObject[] args) [0x00016] in <63992662b765477a898ef49cdcc99ee2>:0 at System.Dynamic.DynamicMetaObjectBinder.Bind (System.Object[] args, System.Collections.ObjectModel.ReadOnlyCollection`1[T] parameters, System.Linq.Expressions.LabelTarget returnLabel) [0x000de] in <63992662b765477a898ef49cdcc99ee2>:0 at System.Runtime.CompilerServices.CallSiteBinder.BindCore[T] (System.Runtime.CompilerServices.CallSite`1[T] site, System.Object[] args) [0x0001c] in <63992662b765477a898ef49cdcc99ee2>:0 at System.Dynamic.UpdateDelegates.UpdateAndExecuteVoid2[T0,T1] (System.Runtime.CompilerServices.CallSite site, T0 arg0, T1 arg1) [0x00115] in <63992662b765477a898ef49cdcc99ee2>:0 at Ecobee.Net.Authorization+d__18.MoveNext () [0x0010d] in <689d70016f174e4a97eea7c1b2df72fa>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter`1[TResult].GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at HSPI_Ecobee.EcobeeApp+d__67.MoveNext () [0x000b7] in :0 --- End of inner exception stack trace --- at System.Threading.Tasks.Task.ThrowIfExceptional (System.Boolean includeTaskCanceledExceptions) [0x00014] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Threading.Tasks.Task`1[TResult].GetResultCore (System.Boolean waitCompletionNotification) [0x00034] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Threading.Tasks.Task`1[TResult].get_Result () [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at HSPI_Ecobee.WebConfig.postBackProc (System.String page, System.String data, System.String user, System.Int32 userRights) [0x000cf] in :0 ---> (Inner Exception #0) System.MissingFieldException: Field 'Mono.CSharp.CompilerSettings.WarningLevel' not found. at Microsoft.CSharp.RuntimeBinder.CSharpInvokeMemberBinder.FallbackInvokeMember (System.Dynamic.DynamicMetaObject target, System.Dynamic.DynamicMetaObject[] args, System.Dynamic.DynamicMetaObject errorSuggestion) [0x00006] in <7175e130f4634a60b0a49adbfc45babc>:0 at System.Dynamic.InvokeMemberBinder.FallbackInvokeMember (System.Dynamic.DynamicMetaObject target, System.Dynamic.DynamicMetaObject[] args) [0x00000] in <63992662b765477a898ef49cdcc99ee2>:0 at System.Dynamic.DynamicMetaObject.BindInvokeMember (System.Dynamic.InvokeMemberBinder binder, System.Dynamic.DynamicMetaObject[] args) [0x0000b] in <63992662b765477a898ef49cdcc99ee2>:0 at System.Dynamic.InvokeMemberBinder.Bind (System.Dynamic.DynamicMetaObject target, System.Dynamic.DynamicMetaObject[] args) [0x00016] in <63992662b765477a898ef49cdcc99ee2>:0 at System.Dynamic.DynamicMetaObjectBinder.Bind (System.Object[] args, System.Collections.ObjectModel.ReadOnlyCollection`1[T] parameters, System.Linq.Expressions.LabelTarget returnLabel) [0x000de] in <63992662b765477a898ef49cdcc99ee2>:0 at System.Runtime.CompilerServices.CallSiteBinder.BindCore[T] (System.Runtime.CompilerServices.CallSite`1[T] site, System.Object[] args) [0x0001c] in <63992662b765477a898ef49cdcc99ee2>:0 at System.Dynamic.UpdateDelegates.UpdateAndExecuteVoid2[T0,T1] (System.Runtime.CompilerServices.CallSite site, T0 arg0, T1 arg1) [0x00115] in <63992662b765477a898ef49cdcc99ee2>:0 at Ecobee.Net.Authorization+d__18.MoveNext () [0x0010d] in <689d70016f174e4a97eea7c1b2df72fa>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <8f2c484307284b51944a1a13a14c0266>:0 at System.Runtime.CompilerServices.TaskAwaiter`1[TResult].GetResult () [0x00000] in <8f2c484307284b51944a1a13a14c0266>:0 at HSPI_Ecobee.EcobeeApp+d__67.MoveNext () [0x000b7] in :0 <---
        Apr-02 11:18:41	 	Ecobee	ERROR One or more errors occurred.
        Apr-02 11:18:41	 	Ecobee	DEBUG Response= { "ecobeePin": "w5nk", "code": "eWKMaXZIAUf5bzPl04q0yrP7vKMLZuKA", "scope": "smartWrite", "expires_in": 9, "interval": 30 }
        Apr-02 11:18:40	 	Ecobee	DEBUG GET https://api.ecobee.com/authorize?response_type=ecobeePin&scope=smartWrite&client_id=aQLWgv1alPoUfBnA5Ez52iRujqkJJdcP&format=json
          did you remove those dll files from /usr/local/HomeSeer? copying them in /bin is not enough.
          Then restart the plug-in
            That Got it!!!! Thanks
              M apologies for my ignorance here:
              Where do I find these files? (I'm guessing it is not int he HS3 software interface.)
              From the user guide
              "Note:
              On Linux, if you have Mono.CSharp.dll and CSScriptLibrary.dll in the root HomeSeer folder you must move them to the bin folder. (This problem is already fixed on recent HS3 versions)"
              System info:
              Current Date/Time: 5/31/2019 2:58:35 PM
              HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.531
              Linux version: Linux HomeTrollerZeeS2V2 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
              System Uptime: 0 Days 0 Hours 11 Minutes 42 Seconds
              IP Address: 172.16.xx
              Number of Devices: 72
              Number of Events: 94
              Available Threads: 396
              HSTouch Enabled: True
              Event Threads: 1
              Event Trigger Eval Queue: 0
              Device Exec Queue: 0
              HSTouch Event Queue: 0
              Email Send Queue: 0
              Enabled Plug-Ins
              3.0.19.0: BLLock
              2.0.27.0: BLOccupied
              3.0.0.32: Ecobee
              3.9.610.5: HSBuddy
              3.0.1.190: Z-Wave
                From the user guide
                "Note:
                System info:
                Event Threads: 1
                Email Send Queue: 0
                Enabled Plug-Ins
                3.0.19.0: BLLock
                3.0.0.32: Ecobee
                3.9.610.5: HSBuddy
                3.0.1.190: Z-Wave
                You need to connect to your Zee through SSH using putty:
                Follow the 7 first steps of the instructions in this thread: https://forums.homeseer.com/forum/ho...re-using-putty
                  ok thanks... I think. Didn't realize all this was involved.
                  Was able to get to this in the Command Prompt window:
                  homeseer@HomeTrollerZeeS2V2:/usr/local/HomeSeer $
                  Now what?
                      if the dll files are not there, this is not the cause of the problem.
                      Can you describe the problem you have and post the logs you get?
                        When I click "Ecobee Authorization" nothing happens.
                          please set the log level to debug from the config page, then capture again the problem
                            May-31 4:20:53 PM Ecobee DEBUG System.AggregateException: One or more errors occurred. ---> System.Threading.Tasks.TaskCanceledException: A task was canceled. --- End of inner exception stack trace --- at System.Threading.Tasks.Task.ThrowIfExceptional (System.Boolean includeTaskCanceledExceptions) <0x74e6904c + 0x0003c> in :0 at System.Threading.Tasks.Task`1[TResult].GetResultCore (System.Boolean waitCompletionNotification) <0x74e50ec0 + 0x00073> in :0 at System.Threading.Tasks.Task`1[TResult].get_Result () <0x74e50e60 + 0x00027> in :0 at HSPI_Ecobee.WebConfig.postBackProc (System.String page, System.String data, System.String user, System.Int32 userRights) <0x71fbc000 + 0x001a7> in :0 ---> (Inner Exception #0) System.Threading.Tasks.TaskCanceledException: A task was canceled.<---
                            May-31 4:20:53 PM Ecobee ERROR One or more errors occurred.
                            May-31 4:20:32 PM Z-Wave Device: First Floor Kitchen Watts Set to 37.888 (37.888 Watts)
                            May-31 4:20:23 PM Ecobee DEBUG GET https://api.ecobee.com/authorize?res...cP&format=json
                              What's your version of mono? You need 4.8 or later, read this thread
                              https://forums.homeseer.com/forum/th...-was-cancelled
                              If this is a Zee, there is a guide here: https://helpdesk.homeseer.com/articl...e-to-mono-5-12
