Originally posted by CinBRandon
View Post
Ecobee Config=> Authorization
- Likes 1
Thanks. This morning, while away from the house, out of the blue, this dawned on me.
In my Ecobee Account, do I need to remove the the current "ecobee Homeseer Plug-in" and add a new application?
Originally posted by CinBRandon View PostI had to re-image my card for my Zee, and restore from a back-up (as instructed from Homeseer help), for another issue. Now my Ecobee devices are present in HS3, but do not seem to be connected to my Ecobee's. I did the steps above to install Mono5. But they still do no seem to be responding. Any help is appreciated.
info from PuTTY:
Mono JIT compiler version 5.18.1.0 (tarball Fri Mar 15 21:12:47 UTC 2019)
Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-proj ect.com
TLS: __thread
SIGSEGV: normal
Notifications: epoll
Architecture: armel,vfp+hard
Disabled: none
Misc: softdebug
Interpreter: yes
LLVM: yes(600)
Suspend: preemptive
GC: sgen (concurrent by default)
the plugin periodically refresh the authorization token it uses to connect to Ecobee servers, if you use an old back-up it is probably trying to use an expired token.
info from PuTTY:
TLS: __thread
SIGSEGV: normal
Disabled: none
Misc: softdebug
Interpreter: yes
LLVM: yes(600)
Suspend: preemptive
ok. I think I have it working. That was quite the task for a non-computer programmer. thanks for sticking with me.
Haven't done much with it yet, but I did send a message to my Ecobee. The time of the message, displayed on the Ecobee screen, was off by 4 hours. (I'm Central time).
any thoughts?
Originally posted by CinBRandon View PostMay-31 4:20:53 PM Ecobee DEBUG System.AggregateException: One or more errors occurred. ---> System.Threading.Tasks.TaskCanceledException: A task was canceled. --- End of inner exception stack trace --- at System.Threading.Tasks.Task.ThrowIfExceptional (System.Boolean includeTaskCanceledExceptions) <0x74e6904c + 0x0003c> in :0 at System.Threading.Tasks.Task`1[TResult].GetResultCore (System.Boolean waitCompletionNotification) <0x74e50ec0 + 0x00073> in :0 at System.Threading.Tasks.Task`1[TResult].get_Result () <0x74e50e60 + 0x00027> in :0 at HSPI_Ecobee.WebConfig.postBackProc (System.String page, System.String data, System.String user, System.Int32 userRights) <0x71fbc000 + 0x001a7> in :0 ---> (Inner Exception #0) System.Threading.Tasks.TaskCanceledException: A task was canceled.<--- May-31 4:20:53 PM Ecobee ERROR One or more errors occurred. May-31 4:20:32 PM Z-Wave Device: First Floor Kitchen Watts Set to 37.888 (37.888 Watts) May-31 4:20:23 PM Ecobee DEBUG GET https://api.ecobee.com/authorize?res...cP&format=json
What's your version of mono? You need 4.8 or later, read this thread
https://forums.homeseer.com/forum/th...-was-cancelled
If this is a Zee, there is a guide here: https://helpdesk.homeseer.com/articl...e-to-mono-5-12
- Likes 1
May-31 4:20:53 PM Ecobee DEBUG System.AggregateException: One or more errors occurred. ---> System.Threading.Tasks.TaskCanceledException: A task was canceled. --- End of inner exception stack trace --- at System.Threading.Tasks.Task.ThrowIfExceptional (System.Boolean includeTaskCanceledExceptions) <0x74e6904c + 0x0003c> in :0 at System.Threading.Tasks.Task`1[TResult].GetResultCore (System.Boolean waitCompletionNotification) <0x74e50ec0 + 0x00073> in :0 at System.Threading.Tasks.Task`1[TResult].get_Result () <0x74e50e60 + 0x00027> in :0 at HSPI_Ecobee.WebConfig.postBackProc (System.String page, System.String data, System.String user, System.Int32 userRights) <0x71fbc000 + 0x001a7> in :0 ---> (Inner Exception #0) System.Threading.Tasks.TaskCanceledException: A task was canceled.<--- May-31 4:20:53 PM Ecobee ERROR One or more errors occurred. May-31 4:20:32 PM Z-Wave Device: First Floor Kitchen Watts Set to 37.888 (37.888 Watts) May-31 4:20:23 PM Ecobee DEBUG GET https://api.ecobee.com/authorize?res...cP&format=json 1 Photo
if the dll files are not there, this is not the cause of the problem.
Can you describe the problem you have and post the logs you get?
ok thanks... I think. Didn't realize all this was involved.
Was able to get to this in the Command Prompt window:
homeseer@HomeTrollerZeeS2V2:/usr/local/HomeSeer $
Now what?
Originally posted by CinBRandon View PostM apologies for my ignorance here:
Where do I find these files? (I'm guessing it is not int he HS3 software interface.)
From the user guide
"Note: On Linux, if you have Mono.CSharp.dll and CSScriptLibrary.dll in the root HomeSeer folder you must move them to the bin folder. (This problem is already fixed on recent HS3 versions)"
System info:
Current Date/Time: 5/31/2019 2:58:35 PM
HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.531
Linux version: Linux HomeTrollerZeeS2V2 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
System Uptime: 0 Days 0 Hours 11 Minutes 42 Seconds
IP Address: 172.16.xx
Number of Devices: 72
Number of Events: 94
Available Threads: 396
HSTouch Enabled: True
Event Threads: 1
Event Trigger Eval Queue: 0
Device Exec Queue: 0
HSTouch Event Queue: 0
Email Send Queue: 0
Enabled Plug-Ins
3.0.19.0: BLLock
2.0.27.0: BLOccupied
3.0.0.32: Ecobee
3.9.610.5: HSBuddy
3.0.1.190: Z-Wave
Follow the 7 first steps of the instructions in this thread: https://forums.homeseer.com/forum/ho...re-using-putty
