Ecobee remote sensors all have same name
  • Ecobee remote sensors all have same name
    I have 4 Ecobees and 14 remote temperature sensors.
    Setting up a HS event, the dropdown box list 14 identical Ecobee Temperatures.
    I have uniquely identified the sensors by name, room, and floor. In Ecobee they are all uniquely identified.
    How can I tell which Ecobee Temperature is which?
    If this has to be an added feature, the simplest and most robust would be simply to suffix the 4 letter sensor ID to "Ecobee Temperature"
    Sorry if this is a duplicate post. My first post didn't seem to make it.
    From the device management screen, you need to manually change the room/floor attributes for your Temperature devices. Then the devices will appear prefixed with room/floor in the event engine
      Thank you for replying.
      That is exactly what I did, and why I posted.
      None of the Ecobee devices show room, floor or name changes, while all the other non-Ecobee devices do.
        hmm that's weird...
        have you tried to restart HS3?
        if you can't figure it out, can you post some screenshots?
          Thank you. I did a complete shut down, power off reboot, and now it is working as expected. Yay!
          I made subsequent changes that were reflected immediately, and did not require an additional reboot.
          I have been using (trying to use) an Ecobee plugin in Vera, and I'd like to compliment you on a much better solution. Happy to have left Vera.
