Okay, this time it listed errors...
Plug in Will Not Start
then try this:
Code:sudo apt-get -y install libmono-microsoft-csharp4.0-cil
thanksPlugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
My blog: http://www.domogeek.ca/blog/
please do this one too:
Code:sudo apt-get -y install libmono-system-xml-linq4.0-cil
Hi, I initially bought the HomeTroller SEL Pro about 5 weeks ago - upgraded from a Zee S2. The first SEL they sent me I had up and configured with minimal trouble, but it died suddenly (dropped off line and would not power back up - there were no power outages or anything in my area and the unit was plugged into a UPS). HS sent me this current controller as a replacement last week and I've been "fighting" with it ever since.
I'm having other problems with it too (I told HS about all of the issues and they instructed me to work with you separately on the ecobee problem). The first HS Tech, after multiple emails back and forth, has passed me on to a more experienced Tech ( Matt). I've sent him the latest error logs, but HS is closed for Thanksgiving so I doubt I'll hear back from them till next week.
I will try your code suggestion when I get home tonight and post the results.
Thanks for your help.
This sounds like the same issue as this one: https://forums.homeseer.com/forum/ho...r-mono-upgrade
He also has a SEL (though an older one) and got the same errors when trying to install mono-complete. The underlying issue turned out to be that mono-devel, which is a component of mono-complete, has a dependency on a newer version of one of the system libraries on the SEL. The fix was to manually update that library.
To see if this is an issue here, run this command and post output.
Code:dpkg --list | grep libglib2
Edit: post #38 of the other thread is the procedure to manually update libglib2.0.Last edited by zwolfpack; November 21, 2018, 01:32 PM.
Originally posted by zwolfpack View PostThis sounds like the same issue as this one: https://forums.homeseer.com/forum/ho...r-mono-upgrade
Code:sudo apt-get -y install libmono-system-net-http4.0-cil sudo apt-get -y install libmono-system-xml-linq4.0-cil sudo apt-get -y install libmono-microsoft-csharp4.0-cil
I believe we have definitely made progress & the problem may now be solved - here's the data...
Here are the results from the 3 library codes installed via PUTTY:
Here's what I got from the LOG when i filtered for ecobee:Nov-21 5:02:38 PM Ecobee DEBUG Response= { "page": { "page": 1, "totalPages": 1, "pageSize": 1, "total": 1 }, "thermostatList": [ { "identifier": "311054404905", "name": "1st Floor Hallway", "thermostatRev": "181121101545", "isRegistered": true, "modelNumber": "athenaSmart", "brand": "ecobee", "features": "Home,HomeKit", "lastModified": "2018-11-21 10:15:45", "thermostatTime": "2018-11-21 17:02:38", "utcTime": "2018-11-21 22:02:38", "settings": { "hvacMode": "heat", "lastServiceDate": "2018-10-09", "serviceRemindMe": false, "monthsBetweenService": 6, "remindMeDate": "2019-04-09", "vent": "off", "ventilatorMinOnTime": 20, "serviceRemindTechnician": false, "eiLocation": "", "coldTempAlert": 580, "coldTempAlertEnabled": true, "hotTempAlert": 920, "hotTempAlertEnabled": true, "coolStages": 2, "heatStages": 2, "maxSetBack": 100, "maxSetForward": 80, "quickSaveSetBack": 40, "quickSaveSetForward": 40, "hasHeatPump": false, "hasForcedAir": true, "hasBoiler": false, "hasHumidifier": false, "hasErv": false, "hasHrv": false, "condensationAvoid": false, "useCelsius": false, "useTimeFormat12": true, "locale": "en", "humidity": "36", "humidifierMode": "off", "backlightOnIntensity": 10, "backlightSleepIntensity": 2, "backlightOffTime": 60, "soundTickVolume": 0, "soundAlertVolume": 0, "compressorProtectionMinTime": 300, "compressorProtectionMinTemp": 350, "stage1HeatingDifferentialTemp": 5, "stage1CoolingDifferentialTemp": 5, "stage1HeatingDissipationTime": 31, "stage1CoolingDissipationTime": 31, "heatPumpReversalOnCool": true, "fanControlRequired": true, "fanMinOnTime": 0, "heatCoolMinDelta": 40, "tempCorrection": 0, "holdAction": "useEndTime2hour", "heatPumpGroundWater": false, "hasElectric": false, "hasDehumidifier": false, "dehumidifierMode": "on", "dehumidifierLevel": 50, "dehumidifyWithAC": true, "dehumidifyOvercoolOffset": 15, "autoHeatCoolFeatureEnabled": true, "wifiOfflineAlert": false, "heatMinTemp": 450, "heatMaxTemp": 1200, "coolMinTemp": -100, "coolMaxTemp": 1200, "heatRangeHigh": 740, "heatRangeLow": 620, "coolRangeHigh": 790, "coolRangeLow": 670, "userAccessCode": "", "userAccessSetting": 22, "auxRuntimeAlert": 10800, "auxOutdoorTempAlert": 500, "auxMaxOutdoorTemp": 700, "auxRuntimeAlertNotify": false, "auxOutdoorTempAlertNotify": false, "auxRuntimeAlertNotifyTechnician": false, "auxOutdoorTempAlertNotifyTechnician": false, "disablePreHeating": false, "disablePreCooling": false, "installerCodeRequired": false, "drAccept": "always", "isRentalProperty": false, "useZoneController": false, "randomStartDelayCool": 0, "randomStartDelayHeat": 0, "humidityHighAlert": 70, "humidityLowAlert": 30, "disableHeatPumpAlerts": false, "disableAlertsOnIdt": false, "humidityAlertNotify": true, "humidityAlertNotifyTechnician": false, "tempAlertNotify": true, "tempAlertNotifyTechnician": false, "monthlyElectricityBillLimit": 0, "enableElectricityBillAlert": false, "enableProjectedElectricityBillAlert": false, "electricityBillingDayOfMonth": 1, "electricityBillCycleMonths": 1, "electricityBillStartMonth": 1, "ventilatorMinOnTimeHome": 20, "ventilatorMinOnTimeAway": 0, "backlightOffDuringSleep": true, "autoAway": true, "smartCirculation": false, "followMeComfort": true, "ventilatorType": "none", "isVentilatorTimerOn": false, "ventilatorOffDateTime": "", "hasUVFilter": true, "coolingLockout": false, "ventilatorFreeCooling": true, "dehumidifyWhenHeating": false, "ventilatorDehumidify": true, "groupRef": "", "groupName": "", "groupSetting": 0 }, "runtime": { "runtimeRev": "181121220236", "connected": true, "firstConnected": "2017-01-28 22:38:56", "connectDateTime": "2018-11-21 20:48:00", "disconnectDateTime": "2018-11-21 20:47:54", "lastModified": "2018-11-21 22:02:36", "lastStatusModified": "2018-11-21 22:02:36", "runtimeDate": "2018-11-21", "runtimeInterval": 262, "actualTemperature": 690, "actualHumidity": 59, "desiredHeat": 670, "desiredCool": 750, "desiredHumidity": 36, "desiredDehumidity": 50, "desiredFanMode": "auto", "desiredHeatRange": [ 620, 740 ], "desiredCoolRange": [ 670, 790 ] }, "events": [ { "type": "template", "name": "_Default_", "running": false, "startDate": "2035-01-01", "startTime": "00:00:00", "endDate": "2035-01-01", "endTime": "23:59:59", "isOccupied": false, "isCoolOff": true, "isHeatOff": false, "coolHoldTemp": 670, "heatHoldTemp": 650, "fan": "auto", "vent": "off", "ventilatorMinOnTime": 5, "isOptional": true, "isTemperatureRelative": false, "coolRelativeTemp": 40, "heatRelativeTemp": 40, "isTemperatureAbsolute": false, "dutyCyclePercentage": 255, "fanMinOnTime": 0, "occupiedSensorActive": false, "unoccupiedSensorActive": false, "drRampUpTemp": 0, "drRampUpTime": 3600, "linkRef": "", "holdClimateRef": "" } ], "program": { "schedule": [ [ "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep" ], [ "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep" ], [ "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep" ], [ "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep" ], [ "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep" ], [ "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep" ], [ "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep" ] ], "climates": [ { "name": "Away", "climateRef": "away", "isOccupied": false, "isOptimized": true, "coolFan": "auto", "heatFan": "auto", "vent": "off", "ventilatorMinOnTime": 20, "owner": "system", "type": "program", "colour": 9021815, "coolTemp": 780, "heatTemp": 620, "sensors": [ { "id": "ei:0:1", "name": "1st Floor Hallway" }, { "id": "rs:101:1", "name": "Family Room" }, { "id": "rs:102:1", "name": "JPs Room" }, { "id": "rs:106:1", "name": "Kitchen" }, { "id": "rs:103:1", "name": "Living Room" }, { "id": "rs:105:1", "name": "Master Bath" }, { "id": "rs:100:1", "name": "Master Bedroom" }, { "id": "rs:104:1", "name": "RJs Room" } ] }, { "name": "Home", "climateRef": "home", "isOccupied": true, "isOptimized": false, "coolFan": "auto", "heatFan": "auto", "vent": "off", "ventilatorMinOnTime": 20, "owner": "system", "type": "program", "colour": 13560055, "coolTemp": 750, "heatTemp": 670, "sensors": [ { "id": "rs:100:1", "name": "Master Bedroom" }, { "id": "rs:101:1", "name": "Family Room" }, { "id": "rs:102:1", "name": "JPs Room" }, { "id": "rs:103:1", "name": "Living Room" }, { "id": "rs:104:1", "name": "RJs Room" }, { "id": "rs:106:1", "name": "Kitchen" } ] }, { "name": "Sleep", "climateRef": "sleep", "isOccupied": true, "isOptimized": false, "coolFan": "auto", "heatFan": "auto", "vent": "off", "ventilatorMinOnTime": 20, "owner": "system", "type": "program", "colour": 2179683, "coolTemp": 730, "heatTemp": 640, "sensors": [ { "id": "rs:101:1", "name": "Family Room" }, { "id": "rs:103:1", "name": "Living Room" }, { "id": "rs:106:1", "name": "Kitchen" } ] } ], "currentClimateRef": "home" }, "remoteSensors": [ { "id": "rs:100", "name": "Master Bedroom", "type": "ecobee3_remote_sensor", "code": "KRTS", "inUse": false, "capability": [ { "id": "1", "type": "temperature", "value": "unknown" }, { "id": "2", "type": "occupancy", "value": "false" } ] }, { "id": "rs:101", "name": "Family Room", "type": "ecobee3_remote_sensor", "code": "QF5C", "inUse": true, "capability": [ { "id": "1", "type": "temperature", "value": "690" }, { "id": "2", "type": "occupancy", "value": "true" } ] }, { "id": "rs:102", "name": "JPs Room", "type": "ecobee3_remote_sensor", "code": "QGSH", "inUse": false, "capability": [ { "id": "1", "type": "temperature", "value": "678" }, { "id": "2", "type": "occupancy", "value": "false" } ] }, { "id": "rs:103", "name": "Living Room", "type": "ecobee3_remote_sensor", "code": "PFBM", "inUse": false, "capability": [ { "id": "1", "type": "temperature", "value": "690" }, { "id": "2", "type": "occupancy", "value": "false" } ] }, { "id": "rs:104", "name": "RJs Room", "type": "ecobee3_remote_sensor", "code": "Q2TJ", "inUse": false, "capability": [ { "id": "1", "type": "temperature", "value": "683" }, { "id": "2", "type": "occupancy", "value": "false" } ] }, { "id": "ei:0", "name": "1st Floor Hallway", "type": "thermostat", "inUse": false, "capability": [ { "id": "1", "type": "temperature", "value": "695" }, { "id": "2", "type": "humidity", "value": "59" }, { "id": "3", "type": "occupancy", "value": "false" } ] }, { "id": "rs:105", "name": "Master Bath", "type": "ecobee3_remote_sensor", "code": "WJFN", "inUse": false, "capability": [ { "id": "1", "type": "temperature", "value": "690" }, { "id": "2", "type": "occupancy", "value": "false" } ] }, { "id": "rs:106", "name": "Kitchen", "type": "ecobee3_remote_sensor", "code": "WC78", "inUse": false, "capability": [ { "id": "1", "type": "temperature", "value": "unknown" }, { "id": "2", "type": "occupancy", "value": "false" } ] } ] } ], "status": { "code": 0, "message": "" } } Nov-21 5:02:37 PM Ecobee DEBUG GET https://api.ecobee.com/1/thermostat?...Bsh7ArRvJas6tF Nov-21 5:02:37 PM Ecobee DEBUG GET https://api.ecobee.com/1/thermostatS...Bsh7ArRvJas6tF Nov-21 5:00:45 PM Ecobee DEBUG Response= { "page": { "page": 1, "totalPages": 1, "pageSize": 1, "total": 1 }, "thermostatList": [ { "identifier": "311054404905", "name": "1st Floor Hallway", "thermostatRev": "181121101545", "isRegistered": true, "modelNumber": "athenaSmart", "brand": "ecobee", "features": "Home,HomeKit", "lastModified": "2018-11-21 10:15:45", "thermostatTime": "2018-11-21 17:00:45", "utcTime": "2018-11-21 22:00:45", "settings": { "hvacMode": "heat", "lastServiceDate": "2018-10-09", "serviceRemindMe": false, "monthsBetweenService": 6, "remindMeDate": "2019-04-09", "vent": "off", "ventilatorMinOnTime": 20, "serviceRemindTechnician": false, "eiLocation": "", "coldTempAlert": 580, "coldTempAlertEnabled": true, "hotTempAlert": 920, "hotTempAlertEnabled": true, "coolStages": 2, "heatStages": 2, "maxSetBack": 100, "maxSetForward": 80, "quickSaveSetBack": 40, "quickSaveSetForward": 40, "hasHeatPump": false, "hasForcedAir": true, "hasBoiler": false, "hasHumidifier": false, "hasErv": false, "hasHrv": false, "condensationAvoid": false, "useCelsius": false, "useTimeFormat12": true, "locale": "en", "humidity": "36", "humidifierMode": "off", "backlightOnIntensity": 10, "backlightSleepIntensity": 2, "backlightOffTime": 60, "soundTickVolume": 0, "soundAlertVolume": 0, "compressorProtectionMinTime": 300, "compressorProtectionMinTemp": 350, "stage1HeatingDifferentialTemp": 5, "stage1CoolingDifferentialTemp": 5, "stage1HeatingDissipationTime": 31, "stage1CoolingDissipationTime": 31, "heatPumpReversalOnCool": true, "fanControlRequired": true, "fanMinOnTime": 0, "heatCoolMinDelta": 40, "tempCorrection": 0, "holdAction": "useEndTime2hour", "heatPumpGroundWater": false, "hasElectric": false, "hasDehumidifier": false, "dehumidifierMode": "on", "dehumidifierLevel": 50, "dehumidifyWithAC": true, "dehumidifyOvercoolOffset": 15, "autoHeatCoolFeatureEnabled": true, "wifiOfflineAlert": false, "heatMinTemp": 450, "heatMaxTemp": 1200, "coolMinTemp": -100, "coolMaxTemp": 1200, "heatRangeHigh": 740, "heatRangeLow": 620, "coolRangeHigh": 790, "coolRangeLow": 670, "userAccessCode": "", "userAccessSetting": 22, "auxRuntimeAlert": 10800, "auxOutdoorTempAlert": 500, "auxMaxOutdoorTemp": 700, "auxRuntimeAlertNotify": false, "auxOutdoorTempAlertNotify": false, "auxRuntimeAlertNotifyTechnician": false, "auxOutdoorTempAlertNotifyTechnician": false, "disablePreHeating": false, "disablePreCooling": false, "installerCodeRequired": false, "drAccept": "always", "isRentalProperty": false, "useZoneController": false, "randomStartDelayCool": 0, "randomStartDelayHeat": 0, "humidityHighAlert": 70, "humidityLowAlert": 30, "disableHeatPumpAlerts": false, "disableAlertsOnIdt": false, "humidityAlertNotify": true, "humidityAlertNotifyTechnician": false, "tempAlertNotify": true, "tempAlertNotifyTechnician": false, "monthlyElectricityBillLimit": 0, "enableElectricityBillAlert": false, "enableProjectedElectricityBillAlert": false, "electricityBillingDayOfMonth": 1, "electricityBillCycleMonths": 1, "electricityBillStartMonth": 1, "ventilatorMinOnTimeHome": 20, "ventilatorMinOnTimeAway": 0, "backlightOffDuringSleep": true, "autoAway": true, "smartCirculation": false, "followMeComfort": true, "ventilatorType": "none", "isVentilatorTimerOn": false, "ventilatorOffDateTime": "", "hasUVFilter": true, "coolingLockout": false, "ventilatorFreeCooling": true, "dehumidifyWhenHeating": false, "ventilatorDehumidify": true, "groupRef": "", "groupName": "", "groupSetting": 0 }, "runtime": { "runtimeRev": "181121215751", "connected": true, "firstConnected": "2017-01-28 22:38:56", "connectDateTime": "2018-11-21 20:48:00", "disconnectDateTime": "2018-11-21 20:47:54", "lastModified": "2018-11-21 21:50:36", "lastStatusModified": "2018-11-21 21:57:51", "runtimeDate": "2018-11-21", "runtimeInterval": 262, "actualTemperature": 690, "actualHumidity": 59, "desiredHeat": 670, "desiredCool": 750, "desiredHumidity": 36, "desiredDehumidity": 50, "desiredFanMode": "auto", "desiredHeatRange": [ 620, 740 ], "desiredCoolRange": [ 670, 790 ] }, "events": [ { "type": "template", "name": "_Default_", "running": false, "startDate": "2035-01-01", "startTime": "00:00:00", "endDate": "2035-01-01", "endTime": "23:59:59", "isOccupied": false, "isCoolOff": true, "isHeatOff": false, "coolHoldTemp": 670, "heatHoldTemp": 650, "fan": "auto", "vent": "off", "ventilatorMinOnTime": 5, "isOptional": true, "isTemperatureRelative": false, "coolRelativeTemp": 40, "heatRelativeTemp": 40, "isTemperatureAbsolute": false, "dutyCyclePercentage": 255, "fanMinOnTime": 0, "occupiedSensorActive": false, "unoccupiedSensorActive": false, "drRampUpTemp": 0, "drRampUpTime": 3600, "linkRef": "", "holdClimateRef": "" } ], "program": { "schedule": [ [ "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep" ], [ "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep" ], [ "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep" ], [ "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep" ], [ "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep" ], [ "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep" ], [ "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "home", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep", "sleep" ] ], "climates": [ { "name": "Away", "climateRef": "away", "isOccupied": false, "isOptimized": true, "coolFan": "auto", "heatFan": "auto", "vent": "off", "ventilatorMinOnTime": 20, "owner": "system", "type": "program", "colour": 9021815, "coolTemp": 780, "heatTemp": 620, "sensors": [ { "id": "ei:0:1", "name": "1st Floor Hallway" }, { "id": "rs:101:1", "name": "Family Room" }, { "id": "rs:102:1", "name": "JPs Room" }, { "id": "rs:106:1", "name": "Kitchen" }, { "id": "rs:103:1", "name": "Living Room" }, { "id": "rs:105:1", "name": "Master Bath" }, { "id": "rs:100:1", "name": "Master Bedroom" }, { "id": "rs:104:1", "name": "RJs Room" } ] }, { "name": "Home", "climateRef": "home", "isOccupied": true, "isOptimized": false, "coolFan": "auto", "heatFan": "auto", "vent": "off", "ventilatorMinOnTime": 20, "owner": "system", "type": "program", "colour": 13560055, "coolTemp": 750, "heatTemp": 670, "sensors": [ { "id": "rs:100:1", "name": "Master Bedroom" }, { "id": "rs:101:1", "name": "Family Room" }, { "id": "rs:102:1", "name": "JPs Room" }, { "id": "rs:103:1", "name": "Living Room" }, { "id": "rs:104:1", "name": "RJs Room" }, { "id": "rs:106:1", "name": "Kitchen" } ] }, { "name": "Sleep", "climateRef": "sleep", "isOccupied": true, "isOptimized": false, "coolFan": "auto", "heatFan": "auto", "vent": "off", "ventilatorMinOnTime": 20, "owner": "system", "type": "program", "colour": 2179683, "coolTemp": 730, "heatTemp": 640, "sensors": [ { "id": "rs:101:1", "name": "Family Room" }, { "id": "rs:103:1", "name": "Living Room" }, { "id": "rs:106:1", "name": "Kitchen" } ] } ], "currentClimateRef": "home" }, "remoteSensors": [ { "id": "rs:100", "name": "Master Bedroom", "type": "ecobee3_remote_sensor", "code": "KRTS", "inUse": false, "capability": [ { "id": "1", "type": "temperature", "value": "unknown" }, { "id": "2", "type": "occupancy", "value": "false" } ] }, { "id": "rs:101", "name": "Family Room", "type": "ecobee3_remote_sensor", "code": "QF5C", "inUse": true, "capability": [ { "id": "1", "type": "temperature", "value": "690" }, { "id": "2", "type": "occupancy", "value": "true" } ] }, { "id": "rs:102", "name": "JPs Room", "type": "ecobee3_remote_sensor", "code": "QGSH", "inUse": false, "capability": [ { "id": "1", "type": "temperature", "value": "678" }, { "id": "2", "type": "occupancy", "value": "false" } ] }, { "id": "rs:103", "name": "Living Room", "type": "ecobee3_remote_sensor", "code": "PFBM", "inUse": false, "capability": [ { "id": "1", "type": "temperature", "value": "690" }, { "id": "2", "type": "occupancy", "value": "false" } ] }, { "id": "rs:104", "name": "RJs Room", "type": "ecobee3_remote_sensor", "code": "Q2TJ", "inUse": false, "capability": [ { "id": "1", "type": "temperature", "value": "685" }, { "id": "2", "type": "occupancy", "value": "false" } ] }, { "id": "ei:0", "name": "1st Floor Hallway", "type": "thermostat", "inUse": false, "capability": [ { "id": "1", "type": "temperature", "value": "695" }, { "id": "2", "type": "humidity", "value": "59" }, { "id": "3", "type": "occupancy", "value": "true" } ] }, { "id": "rs:105", "name": "Master Bath", "type": "ecobee3_remote_sensor", "code": "WJFN", "inUse": false, "capability": [ { "id": "1", "type": "temperature", "value": "690" }, { "id": "2", "type": "occupancy", "value": "false" } ] }, { "id": "rs:106", "name": "Kitchen", "type": "ecobee3_remote_sensor", "code": "WC78", "inUse": false, "capability": [ { "id": "1", "type": "temperature", "value": "unknown" }, { "id": "2", "type": "occupancy", "value": "false" } ] } ] } ], "status": { "code": 0, "message": "" } } Nov-21 5:00:45 PM Ecobee DEBUG GET https://api.ecobee.com/1/thermostat?...Bsh7ArRvJas6tF Nov-21 5:00:44 PM Ecobee DEBUG GET https://api.ecobee.com/1/thermostatS...Bsh7ArRvJas6tF Nov-21 5:00:44 PM Ecobee DEBUG POST https://api.ecobee.com/token?grant_t...cP&format=json Nov-21 4:59:14 PM Ecobee DEBUG Response= { "ecobeePin": "7gkn", "code": "DtkDiMS1XsE7u4WtoE7GvueiDh60xVKw", "scope": "smartWrite", "expires_in": 9, "interval": 30 } Nov-21 4:59:14 PM Ecobee DEBUG GET https://api.ecobee.com/authorize?res...cP&format=json I honestly don't know how to read the LOG, but knew you would. I have been able to access the ecobee Configuration Tab and it generated a code and I've successfully added the ecobee pliugin app to my ecobee account (just as I had it with the Zee S2 and previous SEL Pro (before it died).Nov-21 4:58:37 PM Ecobee WARNING The Ecobee plugin hasn't been authorized to access your Ecobee account, please go to the config page to authorize.
Guess I just need to wait and watch that the events trigger 7 execute properly now. Thanks again for your help! I truly appreciate everyone on the Forum - great community!
