Hi Spud,
As you know, winter kicked into high gear fairly soon in our area this year. Things that I was hoping to test or validate in January-February with my new Daikin (Ecobee) T-stats are happening right now. So after some observations I was wondering if you could implement the followings change :
Observations :
- In the configuration "Response" section there is a variable called "hasElectric : true/false". If the T-stat is configured with "Aux. Heat", this flag is "true". It is part of the system configuration and not something that you would toggle ON/OFF so having a device for it is not really useful. However it becomes helpful for the next point.
- When it gets very cold, both the "Heat pump" and "Aux. Heat" can be engaged. The stat "Response" will be like this : "XXXXXXX670:auxHeat1,fan,heatPump".
- You do have a device showing "Fan status" and a second one showing "HVAC status" as either "Idle, Heating, Cooling" but there is no way to tell if "Aux. Heat" is ON/OFF
Request :
- What would be nice is that : IF "hasElectric" = true then create a device called "Auxiliary heat status" showing ON-OFF state.
or
- Just add a new "Aux. Heat status" device and T-stat without Aux heat enabled will always show OFF.
Hoping this is somewhat clear.
Regards.
Michel
Observations :
Request :
or
Regards.
Michel
