ERROR A task was cancelled.
    Hi Spud,
    Guessing it is related to some Ecobee's server lag but can you please confirm the exact meaning of this message. Getting it once in a while.
Name:	Annotation 2019-12-18 165355.jpg
    Same.... ran test and all seems to work, but see these daily.
      So, looks like we had the same error at the same time.... likely a communication issue on Ecobee's side
      This is my log entry though...
      Dec-19 08:03:22 Ecobee ERROR The operation was canceled.
        interesting. mine a different time, even adjusting for timezone.
        Dec-19 2:01:34 AM Ecobee ERROR A task was canceled.
        Dec-19 2:01:04 AM Ecobee ERROR A task was canceled.
          Possibly accessing a different AWS\hosted system? Maybe an update rolled out last night? Everything seems to be working fine at the moment.
            Well... the filter helps here, last 48hrs
            Dec-19 17:01:58 Ecobee ERROR The operation was canceled.
            Dec-19 05:02:08 Ecobee ERROR The operation was canceled.
            Dec-18 23:37:58 Ecobee ERROR The operation was canceled.
            Dec-18 23:04:37 Ecobee ERROR The SSL connection could not be established, see inner exception.
            Dec-18 23:04:09 Ecobee ERROR The operation was canceled.
            Dec-18 23:01:56 Ecobee ERROR The operation was canceled.
            Dec-18 22:06:05 Ecobee ERROR The operation was canceled.
            Dec-18 22:03:03 Ecobee ERROR The operation was canceled.
            Dec-18 18:01:49 Ecobee ERROR The operation was canceled.
            Dec-18 17:02:56 Ecobee ERROR The operation was canceled.
            Dec-18 05:02:34 Ecobee ERROR The operation was canceled.
            Dec-18 05:01:24 Ecobee ERROR The operation was canceled.
            Dec-18 05:00:51 Ecobee ERROR The operation was canceled.
              I know that Ecobee is often having issues with connectivity to their servers. Still would be nice if Spud could confirm what triggers the error in is code.
              It is strange that Attika is having a different message text for what appears to be a very similar issue.
                I'm running HS3-Standard on Raspbian Lite, probably just a difference in system language if you're on Windows.
                  A bunch more of these today around 2, 5 and 8am ish my time.
                  ​​​​​​@spud, any thoughts on this???
                    "a task was canceled" is a very generic error, it could be a connectivity issue with the Ecobee servers, it could be something else. I would need to see the logs at debug level to investigate more.
