I upgraded to HS4 using the HS3 ecobee plugin. Is it normal to see two different groups and having Basement Addition SE as that icon? Should Basement Addition be the root device?
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
ATTENTION INSTEON HUB USERS: Not happy about the new fees? We can help! Learn More Now
