Ecobee not found
    Ecobee not found
    It is 12/28 ... and I just notices that the last sync with ecobee happened on 12/12. I did restart HS and I also reset the thermostats and I also re-authorized the plugin per instructions.
    Still no sync. In the logs I see below. I am not sure what to try next. My ecobee phone app is working fine. And the web browser also works fine. And the thermostats appear to be working fine.
    Anyone have an idea?
    Thanks!
    12/28/2020 5:42:54 AM
    Legacy-Plugin Ecobee ERROR Cannot find thermostat 521775476976
    HomeSeer Device Control Device: Ecobee Target Temperature Low to (value) °F (71) by/from: CAPI Control Handler
    What version of the plugin are you running?
      how do I find out ... the plugin config has no version
        Plugin - Manage
          It was under plugins - installed ... version 3.0.0.33
            you should update to version BETA 3.0.0.36
            if you still have the problem with this version, set the log level to Debug from the config page, restart the plugin and post what you get in the logs.
              That worked!!! thank you very much!!
