Originally posted by wposner
View Post
Ecobee Plug-in - Beta Testing
This is a sticky topic.
Regarding the Thermostat API for HomeSeer, can you add Current Program to the list of status trackable devices and "Resume Program" to the list of Actions in HSTouch? or can that only be changed by HomeSeer?
I was hoping to keep the stock thermostat screen and just add a "Holding TEMP" and "Resume Program" button that changes based on the device you select, rather than create three separate screens for each thermostat again for my iPhone clients.
Originally posted by wposner View PostAwesome! Exactly what I needed. Question--why does it show that the plugin is loaded remotely under the "Enable" column in the Plugin Management page?Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
My blog: http://www.domogeek.ca/blog/
Originally posted by bphillips View PostRegarding the Thermostat API for HomeSeer, can you add Current Program to the list of status trackable devices and "Resume Program" to the list of Actions in HSTouch? or can that only be changed by HomeSeer?
I was hoping to keep the stock thermostat screen and just add a "Holding TEMP" and "Resume Program" button that changes based on the device you select, rather than create three separate screens for each thermostat again for my iPhone clients.Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
Spud, I got this error in the log after HomeSeer was running for about a day. I restarted the plugin and the error appeared on startup, so I restarted my entire server and the error appeared on startup again. Any idea what it might be? I know that one of the plugins I have, JowlHue, uses Newtonsoft JSON and others have had similar errors with that plugin, but I don't have any errors with the JowlHue plugin so I'm not entirely sure if there's a conflict.
ERROR Newtonsoft.Json.JsonSerializationException: Error converting value "autoHome" to type 'Ecobee.Net.EventType'. Path 'type', line 2, position 21. ---> System.ArgumentException: Requested value 'autoHome' was not found. at System.Enum.EnumResult.SetFailure(ParseFailureKind failure, String failureMessageID, Object failureMessageFormatArgument) at System.Enum.TryParseEnum(Type enumType, String value, Boolean ignoreCase, EnumResult& parseResult) at System.Enum.Parse(Type enumType, String value, Boolean ignoreCase) at Newtonsoft.Json.Utilities.EnumUtils.ParseEnumName(String enumText, Boolean isNullable, Type t) at Newtonsoft.Json.Converters.StringEnumConverter.ReadJson(Json Reader reader, Type objectType, Object existingValue, JsonSerializer serializer) --- End of inner exception stack trace --- at Newtonsoft.Json.Converters.StringEnumConverter.ReadJson(Json Reader reader, Type objectType, Object existingValue, JsonSerializer serializer) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.D eserializeConvertable(JsonConverter converter, JsonReader reader, Type objectType, Object existingValue) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.S etPropertyValue(JsonProperty property, JsonConverter propertyConverter, JsonContainerContract containerContract, JsonProperty containerProperty, JsonReader reader, Object target) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.P opulateObject(Object newObject, JsonReader reader, JsonObjectContract contract, JsonProperty member, String id) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.P opulate(JsonReader reader, Object target) at Newtonsoft.Json.JsonSerializer.PopulateInternal(JsonReader reader, Object target) at Newtonsoft.Json.JsonConvert.PopulateObject(String value, Object target, JsonSerializerSettings settings) at Ecobee.Net.ApiObject.OnLoadFrom(String json) at Ecobee.Net.ApiObject.OnLoadFrom(Object dataObject) at CallSite.Target(Closure , CallSite , ApiObject , Object ) at System.Dynamic.UpdateDelegates.UpdateAndExecuteVoid2[T0,T1](CallSite site, T0 arg0, T1 arg1) at CallSite.Target(Closure , CallSite , ApiObject , Object ) at Ecobee.Net.ApiObject.LoadFrom(Object dataObject) at CallSite.Target(Closure , CallSite , Event , Object ) at Ecobee.Net.ApiObjectCollection`1.OnLoad(Object dataObject) at CallSite.Target(Closure , CallSite , ApiObjectCollection`1 , Object ) at Ecobee.Net.ApiObjectCollection`1.Load(Object dataObject) at CallSite.Target(Closure , CallSite , EventList , Object ) at Ecobee.Net.Thermostat.ApplyDetails(Selection selection, Object data) at CallSite.Target(Closure , CallSite , Thermostat , Selection , Object ) at Ecobee.Net.Thermostats.d__12.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSucce ss(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccess AndDebuggerNotification(Task task) at HSPI_Ecobee.EcobeeApp.d__12.MoveNext()
Originally posted by bphillips View PostSpud, I got this error in the log after HomeSeer was running for about a day. I restarted the plugin and the error appeared on startup, so I restarted my entire server and the error appeared on startup again. Any idea what it might be? I know that one of the plugins I have, JowlHue, uses Newtonsoft JSON and others have had similar errors with that plugin, but I don't have any errors with the JowlHue plugin so I'm not entirely sure if there's a conflict.
I will fix it and release a new version.Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
Originally posted by spud View PostIt's not a conflict. The plugin received an event type (autoHome) that it didn't know (because this type is missing in the documentation)
please test version 3.0.0.4, it should fix the errorPlugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
Originally posted by spud View Postplease test version 3.0.0.4, it should fix the error
One more request for whenever you push out another version: Can you change the default status icon for Online so it's a picture of the thermostats? I changed it manually but every day or two it resets back to the yellow "On" icon. Also, no icon appears when the current program is "Hold". Is that normal or am I missing an icon?
Here's what I changed the icon to, to better fit the style of HS3/HSTouch:
You're right, there is no icon for Hold right now
What do you use for "Offline" icon? I think I'm going to stick with the standard HS icons for now.Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
Originally posted by spud View PostIf you change the icon for a device status it should only revert back to the default one if you upgrade to a new version.
Sometimes when I deploy HSTouch projects the ecobee icon changes back to the Yellow "on" one. It's a little strange, but I can deal with it.
I'm using the regular offline icon for now since none of my thermostats have gone offline yet.
Originally posted by kideon View PostJust got the plugin installed and it's working well! Is it possible to show the current equipment running (Heat, Cool Aux)?Plugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
the Ecobee plugin is now in the updater ("Thermostat / HVAC" section) and in the store: http://store.homeseer.com/store/Prod...HS3-P2085.aspxPlugins: Nest - IFTTT - Kinect - UPB - Kodi - iTunes - Airplay Speak - EnvisaLink DSC / Ademco - DirecTV - Wiimote - Hyperion - Autelis - EasyTrigger - Alexa - Ecobee - Sinope - RaspberryIO - ImperiHome - Chromecast
