Originally posted by Rick21
View Post
The error says that one of the lib of .Net framework can't be loaded. This is usually a rights problem, that's why I mentioned to turn off any anti virus because sometime they can prevent the plugin to access other files on your system.
Can you run any other plugin on your system?
One thing you can try is to open a windows command prompt with administrator rights, then cd to your HS3 dir, then type HSPI_Ecobee.exe to start the plugin manually.
