Installation trouble
    I think I got a corrupted install. It thinks it installed correctly. The install was before a windows update rebooted the machine. I know I have greater than .Net 4.5 installed. The OS is Win10.
    Log files below:
    Dec-17 1:29:54 PM Info Plugin Ecobee with instance: has disconnected
    Dec-17 1:29:53 PM Plug-In Finished initializing plug-in Ecobee
    Dec-17 1:29:52 PM Ecobee INFO Ecobee version 3.0.0.13
    Dec-17 1:29:52 PM Info Plugin Ecobee has connected. IP:127.0.0.1:53986
    Dec-17 1:29:52 PM Plug-In Interface Ecobee is running as a trial, 29 days remaining.
    Dec-17 1:29:41 PM Updater Install/Update of package Ecobee was successful.
    Dec-17 1:29:41 PM Updater Copying file: C:\Program Files\HomeSeer HS3\Config\\Ecobee.ini
    Dec-17 1:29:41 PM Updater Extraction Complete.
    Dec-17 1:29:41 PM Updater Extracting files from zip file: images.zip
    Dec-17 1:29:41 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\Ecobee\System.Time.dll
    Dec-17 1:29:41 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\Ecobee\Ecobee.Net.dll
    Dec-17 1:29:41 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\Ecobee\Newtonsoft.Json.dll
    Dec-17 1:29:41 PM Updater Making dir: C:\Program Files\HomeSeer HS3\bin\Ecobee\
    Dec-17 1:29:41 PM Updater Copying file: C:\Program Files\HomeSeer HS3\HSPI_Ecobee.exe.config
    Dec-17 1:29:40 PM Updater Installing package Ecobee
    Dec-17 1:29:40 PM Updater Update HSPI_Ecobee.exe downloaded successfully
    Dec-17 1:29:39 PM Updater Downloading update: Ecobee
    Dec-17 1:29:39 PM Updater Starting download of updates
    Error message:
    Dec-17 3:00:05 PM Info Plugin Ecobee with instance: has disconnected
    Dec-17 3:00:04 PM Plug-In Finished initializing plug-in Ecobee
    Dec-17 3:00:04 PM Ecobee INFO Ecobee version 3.0.0.13
    Dec-17 3:00:04 PM Info Plugin Ecobee has connected. IP:127.0.0.1:58580
    Dec-17 3:00:04 PM Plug-In Interface Ecobee is running as a trial, 29 days remaining.
    well there is no error messages logged at all...
    try to add the following to Ecobee.ini
    [GENERAL]
    log_level=Debug
    then disable/enable the plugin again...
      Ecobee.ini file was blank. Added now
        and ?
        Ecobee.ini is supposed to be blank after the first install, the lines above are used to get more logs to troubleshoot the problem.
          I was not sure if that ini file was suppose to be empty as some use ini files for configuration. I turned back on the plugin and error message.
          Dec-18 9:24:14 AM
          Ecobee
          Dec-18 9:24:14 AM
          Info
          Plugin Ecobee has connected. IP:127.0.0.1:63890
          Dec-18 9:24:14 AM
          Warning
          I/O interface Ecobee is down, executable is not running, restarting ...
          Dec-18 9:23:45 AM
          Info
          Dec-18 9:23:44 AM
          Ecobee
          Dec-18 9:23:44 AM
          Info
          Plugin Ecobee has connected. IP:127.0.0.1:63871
          Dec-18 9:23:43 AM
          Warning
          Dec-18 9:23:15 AM
          Info
          Dec-18 9:23:13 AM
          Ecobee
          Dec-18 9:23:13 AM
          Info
          Plugin Ecobee has connected. IP:127.0.0.1:63850
          Dec-18 9:23:13 AM
          Warning
          Dec-18 9:22:45 AM
          Info
          Dec-18 9:22:43 AM
          Plug-In
          Dec-18 9:22:43 AM
          Ecobee
          Dec-18 9:22:43 AM
          Info
          Plugin Ecobee has connected. IP:127.0.0.1:63831
          Dec-18 9:22:42 AM
          Plug-In
          Interface Ecobee is running as a trial, 28 days remaining.
            Still seeing the same thing in the logs.
              Spud,
              Do you have any ideas of how I can troubleshot this? I have greater than 4.5 .Net. I have enable the log and the log shows what it did earlier. From what I can tell all the ini file are empty. I finally got it to show the web config page but now it shows "404 Bad Request: /ecobeeconfig." Is there a way to get it to resinstalled?
              Help please.
                do you want me to have a look? If so please install team viewer and send me credentials at spud.webb.4@gmail.com
                  Dec-28 10:28:51 AM Info Plugin Ecobee with instance: has disconnected Dec-28 10:28:50 AM Ecobee INFO Ecobee version 3.0.0.13 Dec-28 10:28:50 AM Info Plugin Ecobee has connected. IP:127.0.0.1:53237 Dec-28 10:28:50 AM Warning I/O interface Ecobee is down, executable is not running, restarting ... Dec-28 10:28:40 AM Warning File does not exist: C:\Program Files\HomeSeer HS3\html\ecobeeconfig Dec-28 10:28:21 AM Info Plugin Ecobee with instance: has disconnected Dec-28 10:28:20 AM Plug-In Finished initializing plug-in Ecobee Dec-28 10:28:20 AM Ecobee INFO Ecobee version 3.0.0.13 Dec-28 10:28:20 AM Info Plugin Ecobee has connected. IP:127.0.0.1:53178 Dec-28 10:28:19 AM Plug-In Interface Ecobee is running as a trial, 18 days remaining. Dec-28 10:28:06 AM Updater Starting download of updates Dec-28 10:28:04 AM Updater Install/Update of package Ecobee was successful. Dec-28 10:28:04 AM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\Config\\Ecobee.ini Dec-28 10:28:04 AM Updater Extraction Complete. Dec-28 10:28:04 AM Updater Extracting files from zip file: images.zip Dec-28 10:28:04 AM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\Ecobee\System.Time.dll Dec-28 10:28:03 AM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\Ecobee\Ecobee.Net.dll Dec-28 10:28:03 AM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\Ecobee\Newtonsoft.Json.dll Dec-28 10:28:03 AM Updater Copying file: C:\Program Files\HomeSeer HS3\HSPI_Ecobee.exe.config Dec-28 10:28:03 AM Updater Copying file: C:\Program Files\HomeSeer HS3\HSPI_Ecobee.exe Dec-28 10:28:03 AM Updater Installing package Ecobee Dec-28 10:28:03 AM Updater Update HSPI_Ecobee.exe downloaded successfully Dec-28 10:28:01 AM Updater Downloading update: Ecobee Dec-28 10:28:01 AM Updater Starting download of updates
                    Sent info.
                      You had a version of Newtonsoft.Json.dll in your HS3 dir that conflicts with the one used by the Ecobee plugin in bin/Ecobee
                      I renamed the one in your HS3 dir to Newtonsoft.Json.old, and it works now.
                        Sorry, I missed you doing that. Thank you. How did yo figure that out?
                          The Newtonsoft.Json.dll installed in the HS3 root folder by other plugins is a common problem (all the dependencies of a plugin are supposed to be installed in bin/pluginName)
                          I enabled developer mode and started the plugin and an error in the console confirmed that was the problem.
                            Spud,
                            Again thank you for the quick response and thank you for telling me where the issue is so that I might be able to help myself and not bother you.
