setting clock in thermostat
  • setting clock in thermostat
    Been using this plugin for a long time. Works great for the most part. One annoying thing is that is doesn't set the thermostat time to keep it synced to Homeseer. Would think the is pretty easy to add to the plugin. Everything else has always worked well. Just thought I'd throw it out there.
    The plugin does set the thermostat time. I think the issue that you are seeing is that the thermostat time update is tied to the runtime hours update. These updates are done separately once an hour.
    I'm guessing that you have not chosen the optional devices for runtime this week and runtime previous week. If you do that, I believe you will start getting the thermostat time updated.
