RC80 Question
  • #31
    That is the way it works. If you have a schedule loaded and the next scheduled time comes, the thermostat will switch to those values, unless you have HOLD on. You can also disable running schedules all together.
    Alan
    • #32
      Terminating Running Schedules
      Alan - Thanks for straightening this out for me. What command terminates the "Running Schedules" altogether as you mention? From your earlier comment, I thought this would occur if you put the thermostat in the "hold" mode.
      • #33
        Bit 2 of register 3 if set makes the thermostat non-programmable, if clear the thermostat runs the schedule.
        You can also disable the schedule by setting all the time registers for the schedule (there are 12 total 4 for weekday, 4 for saturday, and 4 for sunday) to 96. The thermostat treats a 96 interval as having no time. These registers are:
        21, 24, 27, 30, 33, 36, 39, 42, 45 48, 51, and 54
        The easiest way is to use the plug-in which can set all these values for you!
        Alan
        • #34
          Register 3
          Alan- Are any of the other bits in register 3 useful for my external application?
          • #35
            Alan
            Hi there, Can somebody send me the specification of the serial protocol of the
            • #36
              I found it at
              http://board.homeseer.com/showpost.p...41&postcount=3
              Is there any source code available because I would like to interface this thermostat to a Lonworks power line gateway.
              Freeck
