Is there a way to configure the plugin so that the log is not filled with each change of temperature read by the thermostat?
Is there a way to control the fan, or any other controllable item, from a script by addressing the status device code? Based upon the pulldown of the status device from the GUI it looks as if this device should be controllable via script. I'm aware a second script can be called to control the fan and other items.
