I have 16 RC thermostats in my house and consdering re-using HS but having
two questions:
-I cannot locate the RC-202 signal booster recommended by HAI..I know I saw it on the web a few years back, was 200$! Any ways around it? Any substitutes?
-Could I instead install FOUR RS-232 segments (via a usb to 4 serial port) each segment supporting 4 thermostats. If so does HS support FOUR instances of the HAI-Termostat Plug-In. I have seen this wiring recommended on the web by OneHome for such a setup.
thanks in advance...last time I played with HS was 3 years ago and I realize now that the plug-in is more advanced...I kow I had given up at the time.
