16 RC-80 Thermostats- 2 simple questions.
  • 16 RC-80 Thermostats- 2 simple questions.
    I have 16 RC thermostats in my house and consdering re-using HS but having
    two questions:
    -I cannot locate the RC-202 signal booster recommended by HAI..I know I saw it on the web a few years back, was 200$! Any ways around it? Any substitutes?
    -Could I instead install FOUR RS-232 segments (via a usb to 4 serial port) each segment supporting 4 thermostats. If so does HS support FOUR instances of the HAI-Termostat Plug-In. I have seen this wiring recommended on the web by OneHome for such a setup.
    thanks in advance...last time I played with HS was 3 years ago and I realize now that the plug-in is more advanced...I kow I had given up at the time.
  • #2
    partial answer
    one instance of the plug-in can support multple tstats as each stat is setup with a different address.
    regarding the power booster, my undstanding is this is needed for very long runs. can't remember the specs though
    Mark
    HS3 Pro 3.0.0.534
    Hardware: Insteon Serial PLM | AD2USB for Vista Alarm | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
    Plugins: Insteon (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire3 | RFXCOM | NetCAM | MyQ | BLRadar | BLDenon | Jon00 Charting
    Platform: HP h8-1360t, Windows Server 2012 R2, i7-3.4GHz, 16GB memory
    • #3
      yes but can you have four instances of the plug in within HS (i.e each plug in opens a diferrent COM port)
      • #4
        here is the answer to your comm port question
        http://board.homeseer.com/showthread.php?t=115647
        basically, no.
        Mark
        HS3 Pro 3.0.0.534
