controlling RC80 with events
    I had wanted to create an event that would turn on the fan mode on the AC under certain conditions, the problem is that I cannot seem to control this from an event or any other command other than manually doing it from homeseer, any ideas?
    I tested this with an x10 trigger and it works well.
    When setting up an event, choose "HAI Thermostat Actions"
    Under the "Action" tab, there is a drop down list for "Fan" actions.
    Scott
      Scott
      Ah, I found it, thanks... but it does not have the option to delay an action, darn...
      what I am trying to do is turn on the fan only in certain conditions and then turn it back off a set amount of time later.
      Well, I figured out a way, I can insert a wait into the action list... will test and let you know if it does not work.
