no F to display in HS
  • no F to display in HS
    Why not "remove it from the string" when you pull it for use in Main Lobby?
    -Rupp
        Ty,
        I thought you would use more than that for updateing a device in MainLobby. If you can't get the plugin to change I would setup an event that triggers on device value change or device status change on the device that is holding the temp and simply parse this device and populate a new device with only the temp number.
        -Rupp
          I have been trying to figure out how to do that.
          Can you give me any hints? or a link? (tried to search and came up empty)
          Ty
            Ty,
            If you can post an example of what's in the field (exactly) I'll post a script to parse it for you.
            -Rupp
              This script snippet will strip off all characters that are NOT numeric, ".", "+", or "-". Note that this code is setup to handle multiple temp sensors that are stored in an array that is dimensioned by "i" and will require a small modification to work for a single temperature.
              PHP Code:
              For 1 to Sensor_qty
               num
              For 1 To Len(Tnow(i))
              On Error Resume Next
                   c1
              Mid(Tnow(i), k1)
              ' hs.speak "c1 " & c1
                   If IsNumeric(c1) Or c1 = "."  or c1 = "+" or c1 = "-" Then
                num = num & c1
                   Else
                Exit For
                   End If
              c1 ""   'adds a null in case it is already empty ??
               Next
               Tnow(i) = num
              Next
                Rupp and Jeff,
                Thanks for your help!!
                I know NOTHING about scripting so can you please be a little more specific in what info I need to get you?
                There are 3 Temps I need to change:
                Heat Set Point
                Cool Set Point
                Current Temp
                Rupp, You asked for the exact info that are in those "fields". Were do I find that info? I want to make sure I get you exactly what you need. (all I ever do are rules through HS)
                I really cant thank you enough! This plugin is fantastic and it is this last little snag that is killing me.
                Ty
                  Ty,
                  Set up a manual event that's action is "run script". Then select the "switch to advanced view" option. In the Existing or new script name: enter deviceString.txt. Then select the open script window button. Enter this info.
                  sub main()
                  msgbox(hs.deviceString "A1")
                  end sub
                  Then select update and then test. A message box should pop up with the Device string of the device you need to edit. Post this device string for each of the devices you listed in the post prior to this one.
                  -Rupp
                    Rupp,
                    This doesnt seem to work.
                    When I hit test, it refreshes like it is doing something, but nothing pops up.
                    Here is what I used:
                    sub main()
                    msgbox(hs.deviceString "_23")
                    end sub
                    Any ideas?
                    Ty
                      Try:
                      sub main()
                      msgbox(hs.deviceString ("_23"))
                      end sub
                      -Rupp
                        No Go.
                        Same thing.
                        It looks like it is trying to do something but there is no pop up.
                        Ty
                            -Rupp
                              PERFECT!!!!
                              That got it.
                              I just set up an event:
                              Whenever "HAI Current Temp Change"
                              Run "Current Temp.txt" script
                              Works like a charm!
                              Thank you!!!
                              Ty
