fan status wrt system running
  • fan status wrt system running
    i have noticed that the "fan" device does not change to 'on' when the system is running. even though on the plugin status page says the system is running and the fan says running.
    i would like to see the fan device change to on when the fan is clearly running while the system is running.
    anyone else see this or care about it. should i submit a ticket to have this changed in the plug-in
    Mark
    HS3 Pro 3.0.0.534
    I would like to have this feature as well since I am switching my booster fan if the thermostat is running.
      turns out there is a bug in the plug-in. HST is aware.
      no ETA for the revision. however, since hs2.2 was just released, maybe they will focus on plug-in development for a while
      Mark
      HS3 Pro 3.0.0.534
        well i couldn't wait for HST to fix this anymore so i downloaded the rc80 plug-in source code and installed my visual studio c++ compiler and started poking around.
        i think i have found a fix for the fan status issue i posted earlier. i am going to test it for a while and then figure out how to post the updated plug-in
        stay tuned.
        pleased let me know if there are any of issues with the plug-in. i may be able to fix them.
        Mark
        HS3 Pro 3.0.0.534
