RC-100 Thermostat
    RC-100 Thermostat
    Before I buy an HAI-RC100 thermostat, is anyone using one and is it working well with HS2 and the HAI thermostat plugin? Any input would be appreciated.
    Dick
    HS PRO 2.5.0.81, WinXP, IE8, Shuttle XS35V3, 2.13GHz, 4GB, 40GB SSD drive, AC-RF2, ADIOcelot, Message Server, TI103, SNEVL CID, pjcOutlook, MCSTemperature, Powertrigger, BLBackup, BLFloorplan, BLIcon, BLOccupied, BLRadar, BLRfid, BLLogMonitor, ACPUPSD, UltraECM, WeatherXML & Stipus' script connector. 500+ devices, 260+ events, 1-wire weather station + temp/humidity sensors & Oregon Scientific temp & humidity sensors & 2 Brultech ECM-1240s
    there are some reported issues with the hai tstat plug-in, but in general it works very well with the rc-80a that i own
    My guess is the plug-in will support the rc-100 if the rc-100 uses the same serial connection and has similar buttons on the stat itself. the btns/functions are replicated in the plug-in.
    i would think all the special logic for handling the two stage hvac systems is built into the stat and not the plug-in.
    Mark
    HS3 Pro 3.0.0.534
      I use the plugin with the RC-100 and it works fine.
