anyone interested in testing a new version of the HAI RC Stat Plug-In
    I have modified the PI (current ver 1.0.16) to improve the "Fan" device to be more inline with what is actually happening with the hvac system.
    What is new:
    -the Fan device (dc 2) will change to "On" when the system status is heating, cooling or the Fan Mode is set On.
    -when the fan mode is Auto, the Fan device will now report correctly as well.
    - the Fan triggers are also working correctly (Fan Starts Running, Fan turns Off)
    -added device values to the Fan device, 0-Off, 1-On.
    I have tested it with my RC-80B, but am looking for others to test with their HAI stats.
    Any takers?
    I would recommend saving your current HAI plug-in and HS database, etc before preceeding. That said, I did not have any problems putting this new version into my production environment.
    To install, Just download the attached zip, shutdown HS, replace the current hspi_haithermostat.dll with the new one in the zip, and restart HS. everything should come up just as you left it.
    Please leave me feedback with the HAI RC model you are using, what version of HS you are using, and any problems you encounter.
    Mark
    HS3 Pro 3.0.0.534
    My furnace is just a backup so it does not get used too much, but I'm willing to assure there are no surprises if your version is compatible with HS1.
      Michael,
      my new ver (1.0.17) is basically the same HAI RC PI. if you are using v 1.0.16 the new one will be compatible with HS1 as well.
      Should i just zip it up and attach it to my original msg
      Mark
      HS3 Pro 3.0.0.534
        Originally posted by mnsandler View Post
        Michael,
        I realize this is an old thread, but - are there any improvment in the communication's with the Stat's?
        Skybolt
        -Skybolt
          Are you having problems with this plugin?
          -Rupp
            Skybolt
            No, I never had any comm problems so never looked at it.
            Mark
            HS3 Pro 3.0.0.534
              -Skybolt
                -Skybolt
                  I don't see the problem. the plugin will report an error in the hs log if it can't comm with the tstat. (try unplugging the plug as a test to see the log entries)
                  And hs will only update the "last changed" if the value actually changes for the current value. so it looks like the 1st floor temp dropped a degree from 11:28 to 11:47 and 2nd floor temp held steady.
                  Mark
                  HS3 Pro 3.0.0.534
                    ... so it looks like the 1st floor temp dropped a degree from 11:28 to 11:47 and 2nd floor temp held steady.
                    I agree, except it never does this when I am around - Never the less, I will try this test and also try useing a hair dryer to watch the rise. What is the quickest poll rate supported?
                    Skybolt
                    -Skybolt
                      Skybolt
                      I use 10 secs, but i suppose 1 second is the quickest however you should watch your cpu utilization if you go with 1 sec
                      Mark
                      HS3 Pro 3.0.0.534
                        The reason I ask is that you can enter anything you like throughthe web page, but if you try and use the config under interfaces, it wants 20 sec or greater. And I am not sure if that confuses the issue, if I set it through the web page or through the VB6 interface.
                        I will try setting through the web page and a hair dryer when I get home and see what happens. Thanks for your quick responses, it is appreciated.
                        -Skybolt
                        -Skybolt
                          -Skybolt
                            It seems that the fan monitoring is still off, the plug-in status when the heat comes on, the fan is running, when the thermostat's "FAN" icon is off, also pcstat.exe says the fan is off.
                            Not a big deal, but when summer rolls around and AC is needed this might be an issue. I am runnig the latest .17 posted above.
                            -Skybolt
                            -Skybolt
                              -Skybolt
                              what RC stat model do you have? or does your stat control the fan separately from the heat and cool circuits? did you get the same behavior from the previous version of the plugin (v .16)
                              I have an RC80 which only controls the heat and cooling. the fan is controlled via the furnace itself.
                              Mark
                              HS3 Pro 3.0.0.534
