Load setpoint into variable
  • Load setpoint into variable
    How can I load the heat or cool setpoints into another variable?
    I'm trying to pass the information to a JDS Stargate for display and adjustment on the LCD keypads. I've created a tstat setpoint variable but I can't see how to load that information from the HAI device into it.
    Tim
    -Tim
    HSPro - 3.XXX - Dell mini W7 x32
    Way2 Call
    Elk M1 Gold
    UPB HAI switches
    HAI RC2000 Thermostat
    Is the setpoint value in a device string?
    -Rupp
      Yes, the device string has the degree symbol with it, but the device value has the same number w/o a symbol.
      Maybe the device value would be easier to load to another variable?
      Still need to know how.
      -Tim
      -Tim
      Way2 Call
      Elk M1 Gold
      UPB HAI switches
        When you say a variable, are you writing a script and need to use the value in a script or do you mean to load the value into another virtual device?
        -Rupp
          I have a device from stargate that is a variable.
          I need to copy the thermostat setpoint value into that other variable.
          For example *3 holds the thermostat setpoint. $7 is the stargate variable that I need to load with the value from *3.
          Once $7 has the value, I can display it on my LCD Keypads.
          The first screen shot is *3 that holds the setpoint value. The second is the stargate variable that I need to load with the setpoint.
          -Tim
          -Tim
          Way2 Call
          Elk M1 Gold
          UPB HAI switches
            Try this. Name this file setVar.txt
            sub main()
            sTempVar = hs.deviceValue("*3")
            setDeviceValue "$7", sTempVar
            end sub
            This is for the device value, if you want to "see" the value then you need use SetDeviceString
            -Rupp
              Thanks Rupp,
              I tried it and I'm getting this error:
              12/25/2010 4:36:59 PM - Error - Running script, script run or compile error in file: setVar.txt13:Type mismatch: 'setDeviceValue' in line 3 More info: Type mismatch: 'setDeviceValue'
              -Tim
              Way2 Call
              Elk M1 Gold
              UPB HAI switches
                Sorry it should be hs.setDeviceValue "$7", sTempVar
                -Rupp
                  That was it Rupp.
                  Thank you so much!
                  -Tim
                  -Tim
                  Way2 Call
                  Elk M1 Gold
                  UPB HAI switches
