Load setpoint into variable
  • email68
    Sorry it should be hs.setDeviceValue "$7", sTempVar
    That was it Rupp.
    Thank you so much!
    -Tim
  • Rupp
  • email68
    Thanks Rupp,
    I tried it and I'm getting this error:
    12/25/2010 4:36:59 PM - Error - Running script, script run or compile error in file: setVar.txt13:Type mismatch: 'setDeviceValue' in line 3 More info: Type mismatch: 'setDeviceValue'
  • Rupp
    *3 holds the thermostat setpoint. $7 is the stargate variable that I need to load with the value from *3.
    Once $7 has the value, I can display it on my LCD Keypads.
    Try this. Name this file setVar.txt
    sub main()
    sTempVar = hs.deviceValue("*3")
    end sub
    This is for the device value, if you want to "see" the value then you need use SetDeviceString
  • email68
    When you say a variable, are you writing a script and need to use the value in a script or do you mean to load the value into another virtual device?
    I have a device from stargate that is a variable.
    I need to copy the thermostat setpoint value into that other variable.
    For example *3 holds the thermostat setpoint. $7 is the stargate variable that I need to load with the value from *3.
    The first screen shot is *3 that holds the setpoint value. The second is the stargate variable that I need to load with the setpoint.
    -Tim
  • Rupp
  • email68
    Is the setpoint value in a device string?
    Yes, the device string has the degree symbol with it, but the device value has the same number w/o a symbol.
    Maybe the device value would be easier to load to another variable?
    Still need to know how.
    -Tim
  • Rupp
  • email68
    started a topic Load setpoint into variable
    How can I load the heat or cool setpoints into another variable?
    I'm trying to pass the information to a JDS Stargate for display and adjustment on the LCD keypads. I've created a tstat setpoint variable but I can't see how to load that information from the HAI device into it.
    Tim
