Event not running as expected
  • Event not running as expected
    I made an event that is shown below.
    I was hoping that anytime the thermostat was changed above 68, like 70, HS would set it back to 68.
    It does not respond when the thermostat itself is changed. If the thermostat is changed via HSTouch above 68 the event triggers.
    Any idea how to make it trigger if the thermostat itself is changed?
    -Tim
    HSPro - 3.XXX - Dell mini W7 x32
    Way2 Call
    Elk M1 Gold
    UPB HAI switches
    HAI RC2000 Thermostat
    I believe it's a bug. I opened a bug report, but haven't heard anything back yet. See this thread.
    http://board.homeseer.com/showthread.php?t=145601
      Thanks. Not sure if I should log the same problem or not. I guess I'll wait to see what you hear.
      Does the condition workaround that Rich mentioned work?
      Update: I filled a trouble ticket too, Keep the trouble at the top of the list....
      -Tim
      Way2 Call
      Elk M1 Gold
      UPB HAI switches
