HAI Code Changes for Omnistat2
  • #91
    Kirby,
    any updates on integrating the external temp sensor input into the plugin?
    Mark
    HS3 Pro 3.0.0.534
    • #92
      • #93
        Great. I'll check back in a few weeks.
        good luck with your son's HS setup
        Mark
        HS3 Pro 3.0.0.534
        • #94
          Apr-12 10:46:57 AM Updater Error Installation of package Omnistat 3 failed. Try disabling the plugin first, then re-try the update.
          Apr-12 10:46:57 AM Updater Error Copying source to C:\Program Files (x86)\HomeSeer HS3\HSPI_OMNISTAT_3.exe, detailed error: The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\HSPI_OMNISTAT_3.exe' because it is being used by another process.
          If you do, do the following:
          1) Disable the Omnistat 3 plugin. DO NOT exit HomeSeer.
          2) Rename HSPI_OMNISTAT_3.exe in the HomeSeer root directory to HSPI_OMNISTAT_3.exe.XXX.
          3) Return to Manage Plugins and install the update.
          4) Once the update has been successfully installed, you may remove HSPI_OMNISTAT_3.exe.XXX.
          To go back to normal updates, delete the updater_override.txt file.
          Reply to this thread if you have any issues.
          Kirby
          • #95
            Kirby,
            I've installed the new version. Thanks for posting.
            I'll report back my findings in a few days
            I think it would be helpful to start a new thread for this version, and just put a link from this thread to the new one. Just a thought
            Mark
            HS3 Pro 3.0.0.534
            • #96
              Good idea, Mark.
              I'll try and do that tomorrow.
              • #97
                The new thread for this continuing saga can be found here:http://board.homeseer.com/showthread...50#post1176850
