HS HAI Omnistat plugin to control two RC-2000 stats
  • HS HAI Omnistat plugin to control two RC-2000 stats
    Guys,
    i loaded the HS HAI Omnistat plugin to control two RC-2000 stats
    My basic issue is that the plugin isn't following the stats correctly
    I initially tried 100 baud rate on each and the plugin but didn't have a lot of success getting updates on stat 2 (addr 2)
    i changed the baud rate to 1200 not much better
    is this plugin designed to control/manage two stats? One stat seemed ok at first
    Mark
    HS3 Pro 3.0.0.534
    so i changed the baud rate to 100 for everything and things seems to be working better.
    Mark
    HS3 Pro 3.0.0.534
      I don't understand.
      - Pete
      Auto mator
      HS4 Pro - V4.0.9.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
      HS4 Lite -
