My Omnistat2 is flashing different colors
    the backlight colors alternate between l blue and yellow
    i reset the color and also power cycled the unit. no better
    any other suggestions before i initiate an RMA
    Mark
    HS3 Pro 3.0.0.534
    Curious if it alternates colors when disconnected serially?
    Leviton / HAI are pleasant to deal with regarding RMA issue.
    - Pete
    Auto mator
    Homeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb- Mono 6.12.X
    HS4 Pro - V4.1.7.0 - Ubuntu 18.04/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.12.x
    HS4 Lite -
      i disconnected the serial line and it is still malfunctioning.
      thanks for the suggestion
      I'm off to leviton to RMA the unit
      Mark
      HS3 Pro 3.0.0.534
