How to display the outside temp on HS3 plugin?
  • How to display the outside temp on HS3 plugin?
    On the HS2 plugin for HAI thermostat you could enter an outside temp variable that would show up on the thermostat. How can I do that on the new plugin for HS3?
    -Tim
    HSPro - 3.XXX - Dell mini W7 x32
    Way2 Call
    Elk M1 Gold
    UPB HAI switches
    HAI RC2000 Thermostat
    No way to do this?
    -Tim
    Way2 Call
    Elk M1 Gold
    UPB HAI switches
      If you use the free alternative plugin that I wrote, you would specify the HS device that has the temperature using the configuration screen.
      Read about it at http://board.homeseer.com/showthread.php?t=174446
        Thanks. I actually just found it an hour ago and installed it already. It looks great! Thanks. I was trying the Day, Night, Away, and Vacation modes. I couldn't seem to get them to work. I have an RC-2000.
        The modes are changing, but the set points are not.
        -Tim
        Way2 Call
        Elk M1 Gold
        UPB HAI switches
          Since you have an RC-2000 Occupancy is supported natively by the thermostat. If it is not working for you, check the settings on your thermostat and make sure the program mode is set to occupancy.
            ok, will do. Thanks!
            -Tim
            Way2 Call
            Elk M1 Gold
            UPB HAI switches
