Plugin doesn't see thermo (See attachment)
Since you're running a linux-based server (the HS SEL is, I believe?), you'll probably need to do some work to upgrade mono to workaround a bug in the version of mono it ships with.
Can you confirm what version of mono it has? Check out the first steps in this thread: Linux HS3 Users - READ ME
If it's 3.2.8, this plugin won't work in your environment. The instructions are in that thread to upgrade to 3.8, which will work, but that's a decision you'll have to make based on your comfort level mucking around in the guts of your HS-provided system.
To this day I still spend time trying to find another way around this, but have yet to have any luck...
First of all... Thank You.
Yes LINUX. Here;s my system specs.
Current Date/Time: 6/3/2017 10:23:46 AM
HomeSeer Version: HS3 Standard Edition 3.0.0.318
Linux version: Linux hometrollerSEL 3.16.0-031600-generic #201408031935 SMP Sun Aug 3 23:56:17 UTC 2014 i686 i686 i686 GNU/Linux System Uptime: 4 Days 18 Hours 11 Minutes 32 Seconds
IP Address: 192.168.1.154
Number of Devices: 7
Number of Events: 2
Available Threads: 199
"3.16.0" - Is this the LINUX version? If not where can I find it?
