This thermostat uses a CR2032 coin cell to back up the clock if power is lost. However, if there is a power lost, and the clock does not back up( due to dead coin cell or other issue), the thermostat will not continue to operate the HVAC unit unit the clock is reset. I don't use a program so the clock isn't important. Is there any setting, where the HVAC will start to operate again if the clock is not re st?
Honeywell Themostat TH8320ZW Reset Issue
GuestTags: None
Originally posted by R Alan View PostThis thermostat uses a CR2032 coin cell to back up the clock if power is lost. However, if there is a power lost, and the clock does not back up( due to dead coin cell or other issue), the thermostat will not continue to operate the HVAC unit unit the clock is reset. I don't use a program so the clock isn't important. Is there any setting, where the HVAC will start to operate again if the clock is not re st?
