Thermostat Plug-in Errors in Log?
    Plugin was working just fine for quite some time and after restarting homeseer software on hometroller (HS3) I started receiving this error and it happens all the time:
    Error retrieving data for device 2966934: The remote name could not be resolved:
    'mytotalconnectcomfort.com'.
    I can go to the Honeywell mytotalconnectcomfort.com website and can log into thermostat and control it just fine with no errors. Any help on this issue is appreciated. Thanks Much.....Rick B.
    I'm afraid I don't know what to tell you about that... resolving the DNS name into an IP address in order to connect is a pretty low-level task the OS handles.
    I know you said you were able to go to that website, but was that from your PC or your HS server?
      It is working ok this morning. I forgot to mention that the homeseer myhs servers appeared to be down late last evening. I was unable to connect to myhs remote at the same time that the thermostat plugin wasn't responding. I think they were both related....Thanks....Rick
