I have attached my system profile.
I am posting this here because Homeseer Tech Support suggested that I contact the plug in authors with regard to a long running script.
I have not written aby script for any events in my system.
I purchase a new hometroller in March 2017. As you can see by my system profile I have a large quantity of Insteon devices in my home. Not all are physical devices, many are scenes and programs. I believe these are making homeseer run slow when I use the web interface. I have tried filtering but it seems that some of my filter options include the individual scenes, devices and Programs. For instance, When I try to filter by floor, not only do I get the options for the floors I created, I get the names of devices, scenes and programs from insteon. (see attached screen shot) why am I getting things like " basement dim scene" as a floor. I did not create that as a floor.
I also so get the message from Windows the "10.0.0.132 is not responding due to a long running script." quite frequently. I contacted Homeseer Tech Support and here was the response:
You may want to check all of your events and if you do not have any then ask the plugin authors if their plugin is running a script because that's the only way this message gets displayed. A long running script can cause your system to drag to a crawl.
Please help.
Current Date/Time: 1/13/2018 2:53:54 PM
HomeSeer Version: HS3 Pro Edition 3.0.0.368
Operating System: Microsoft Windows Embedded Standard - Work Station
System Uptime: 2 Days 6 Hours 56 Minutes 46 Seconds
IP Address: 10.0.0.132
Number of Devices: 780
Number of Events: 28
Available Threads: 200
License: Registered
License: 78230
User Name and Access Level: XXXXX
WAN IP Address: XXXXXXXXXXXX
Web Server Port: XX
Enabled Plug-Ins
2.0.41.0: BLBackup
1.1.6.0: Honeywell WiFi Thermostat
3.0.0.46: ISYInsteon
3.0.2.0: Napco Gemini
Please help.
License: Registered
License: 78230
Web Server Port: XX
Enabled Plug-Ins
2.0.41.0: BLBackup
