I am getting these errors:
Jan-15 8:51:54 AM Honeywell WiFi Thermostat Failed to retrieve thermostat data - error occurred, will retry
Jan-15 8:51:54 AM Honeywell WiFi Thermostat Error retrieving data for device 2548087: The remote server returned an error: (403) Forbidden.
Jan-15 8:09:22 AM Honeywell WiFi Thermostat Failed to retrieve thermostat data - error occurred, will retry
Jan-15 8:09:22 AM Honeywell WiFi Thermostat Error retrieving data for device 2548143: The remote server returned an error: (401) Unauthorized.
Jan-15 8:08:03 AM Info Amazon Echo Discovery requested, version: 2
Jan-15 8:07:25 AM Honeywell WiFi Thermostat Failed to retrieve thermostat data - error occurred, will retry
Jan-15 8:07:25 AM Honeywell WiFi Thermostat Error retrieving data for device 2542723: The remote server returned an error: (401) Unauthorized.
Jan-15 8:07:05 AM Honeywell WiFi Thermostat Failed to retrieve thermostat data - error occurred, will retry
Jan-15 8:07:05 AM Honeywell WiFi Thermostat Error retrieving data for device 2548116: The remote server returned an error: (401) Unauthorized.
Jan-15 8:07:02 AM Honeywell WiFi Thermostat Failed to retrieve thermostat data - error occurred, will retry
Jan-15 8:07:02 AM Honeywell WiFi Thermostat Error retrieving data for device 2548017: The remote server returned an error: (401) Unauthorized.
Jan-15 8:06:16 AM Honeywell WiFi Thermostat Failed to retrieve thermostat data - error occurred, will retry
Jan-15 8:06:16 AM Honeywell WiFi Thermostat Error retrieving data for device 2548087: The remote server returned an error: (401) Unauthorized.
Jan-15 8:04:19 AM Honeywell WiFi Thermostat Failed to retrieve thermostat data - error occurred, will retry
Jan-15 8:04:19 AM Honeywell WiFi Thermostat Error retrieving data for device 2548143: The remote server returned an error: (403) Forbidden.
I have attached all the information you requested in your " Help me Help You" thread.
I also need to know if your plug in runs script in an unrelated matter. See Homeseer Running Sluggish in this forum posted yesterday.
HS3 Pro Edition 3.0.0.368 (Windows)
Plug in Version (1.1.12)
Thermostats don't run according to events, times, triggers due to communication problems.
Windows Embedded Standard ( Windows 7)
Honeywell TH9320WF5003 Wi-Fi 9000 Color Touch Screen Programmable
