I installed the plugin and after entering credentials and setting up one thermostat, when I tried to add another, this page "HW_Wifi_Tstat_Config" is blank and hangs there. So, I disabled the plugin, deleted it, and deleted all the TSAT files. After reinstalling, I have the same issue. What's the fix?
HomeSeer Version: HS3 Pro Edition 3.0.0.398
Elliott
PS: Despite doing the above for a "clean" re-install, there is a log file entry generated as follows:
1/22/2018 09:29:21.515 Info Main.Main - Log file location: C:\Program Files (x86)\HomeSeer HS3\Logs\HSPI_SKWARE_HW_WIFI_TSTAT.log
1/22/2018 09:29:59.027 Error HWConnection.Login - Failed to log in
1/22/2018 09:29:59.059 Error ThermostatCommand.ProcessUpdateResults - Failed to retrieve thermostat data - login failed
1/22/2018 09:34:07.029 Info Main.Main - Log file location: C:\Program Files (x86)\HomeSeer HS3\Logs\HSPI_SKWARE_HW_WIFI_TSTAT.log
Elliott
