Updated to 1.2.1.0. Can't communicate with thermostat, home screen shows status failed
Message/Source
Mar-01 2:38:21 PM
Honeywell WiFi Thermostat
Failed to retrieve thermostat data - error occurred, will retry
Mar-01 2:38:21 PM
Error retrieving data for device 1434638: Error: SecureChannelFailure (The authentication or decryption has failed.)
Mar-01 2:33:18 PM
Mar-01 2:33:18 PM
Mar-01 2:32:43 PM
Updater
An item in the Updater is temporarily unavailable: The request timed out Item: http://donmor.ca/HS_Plugin/Caseta/updates.txt
Mar-01 2:30:02 PM
Updater
An item in the Updater is temporarily unavailable: The request timed out Item: http://kazteel.com/HomeSeer3/Insteon...at_updater.txt
Mar-01 2:28:15 PM
Mar-01 2:28:15 PM
Mar-01 2:27:46 PM
Failed to retrieve thermostat data - too soon
Mar-01 2:27:45 PM
Device Control
Device: Sawgrass to Update (1002) by/from: CAPI Control Handler
Mar-01 2:27:43 PM
Mar-01 2:27:43 PM
Mar-01 2:27:39 PM
Device Control
Mar-01 2:27:30 PM
Plug-In
Finished initializing plug-in Honeywell WiFi Thermostat
Mar-01 2:27:25 PM
Log file location: /usr/local/HomeSeer/Logs/HSPI_SKWARE_HW_WIFI_TSTAT.log
Mar-01 2:27:25 PM
Info
Plugin Honeywell WiFi Thermostat has connected. IP:127.0.0.1:54641
Mar-01 2:27:16 PM
Info
Plugin Honeywell WiFi Thermostat with instance: has disconnected
Mar-01 2:27:16 PM
Plug-In
Shutting down Plug-In: Honeywell WiFi Thermostat
Mar-01 2:24:15 PM
Mar-01 2:24:15 PM
Mar-01 2:23:46 PM
Mar-01 2:23:43 PM
Device Control
Mar-01 2:23:42 PM
Mar-01 2:23:42 PM
Mar-01 2:23:42 PM
Device Control
Mar-01 2:23:39 PM
Device Control
Mar-01 2:19:48 PM
Mar-01 2:19:48 PM
Mar-01 2:14:45 PM
Mar-01 2:14:45 PM
Mar-01 2:09:42 PM
Mar-01 2:09:42 PM
Mar-01 2:04:39 PM
Mar-01 2:04:39 PM
Mar-01 1:59:36 PM
Mar-01 1:59:36 PM
Mar-01 1:54:32 PM
Mar-01 1:54:32 PM
Mar-01 1:49:29 PM
Mar-01 1:49:29 PM
Mar-01 1:44:26 PM
Mar-01 1:44:26 PM
Mar-01 1:39:23 PM
Mar-01 1:39:23 PM
Mar-01 1:34:20 PM
Mar-01 1:34:20 PM
Mar-01 1:29:17 PM
Mar-01 1:29:17 PM
Mar-01 1:24:13 PM
Mar-01 1:24:13 PM
Mar-01 1:21:41 PM
MyQ Error
Exception in httpGET|ErrorCount:2|https://myqexternal.myqdevice.com/ap...iceDetails/Get
Mar-01 1:21:27 PM
MyQ Error
Exception in httpGET|ErrorCount:1|https://myqexternal.myqdevice.com/ap...iceDetails/Get
Mar-01 1:19:10 PM
Mar-01 1:19:10 PM
Mar-01 1:15:00 PM
Log Info
The log database is currently 0.13MB in size.
Mar-01 1:14:07 PM
Mar-01 1:14:07 PM
Mar-01 1:09:04 PM
Mar-01 1:09:04 PM
Mar-01 1:07:47 PM
Warning
File does not exist: /usr/local/HomeSeer/html/currentsetting.htm
Mar-01 1:06:00 PM
Energy DB Info
All energy database compacting routines completed.
Mar-01 1:06:00 PM
Energy DB Info
No Records. Vacuuming database to condense.
Mar-01 1:06:00 PM
Energy DB Info
Energy database compaction initiated.
Mar-01 1:04:00 PM
Mar-01 1:04:00 PM
Mar-01 12:58:57 PM
Mar-01 12:58:57 PM
Mar-01 12:53:54 PM
Mar-01 12:53:54 PM
Mar-01 12:48:51 PM
Mar-01 12:48:51 PM
Mar-01 12:43:48 PM
Mar-01 12:43:48 PM
Mar-01 12:38:45 PM
Mar-01 12:38:45 PM
Mar-01 12:33:41 PM
Mar-01 12:33:41 PM
Mar-01 12:28:38 PM
Mar-01 12:28:38 PM
Mar-01 12:23:35 PM
Mar-01 12:23:35 PM
Mar-01 12:18:32 PM
Mar-01 12:18:32 PM
Mar-01 12:13:29 PM
Mar-01 12:13:29 PM
Mar-01 12:08:26 PM
Mar-01 12:08:26 PM
Mar-01 12:03:22 PM
Mar-01 12:03:22 PM
Mar-01 11:58:19 AM
Mar-01 11:58:19 AM
Mar-01 11:53:16 AM
Mar-01 11:53:16 AM
Mar-01 11:48:13 AM
Mar-01 11:48:13 AM
Mar-01 11:43:10 AM
Mar-01 11:43:10 AM
Mar-01 11:38:06 AM
Mar-01 11:38:06 AM
Mar-01 11:33:03 AM
Mar-01 11:33:03 AM
Mar-01 11:28:00 AM
Mar-01 11:28:00 AM
Mar-01 11:22:57 AM
Mar-01 11:22:57 AM
Mar-01 11:17:54 AM
Mar-01 11:17:54 AM
Mar-01 11:12:51 AM
Mar-01 11:12:51 AM
Mar-01 11:07:48 AM
Mar-01 11:07:48 AM
Mar-01 11:02:44 AM
Mar-01 11:02:44 AM
Mar-01 10:57:41 AM
Mar-01 10:57:41 AM
Mar-01 10:52:38 AM
Mar-01 10:52:38 AM
Mar-01 10:47:35 AM
Mar-01 10:47:35 AM
Mar-01 10:42:32 AM
Mar-01 10:42:32 AM
Mar-01 10:37:29 AM
Mar-01 10:37:29 AM
Mar-01 10:32:26 AM
Mar-01 10:32:25 AM
Mar-01 10:28:12 AM
MyQ
Plugin detected device Sawgrass Garage Door changed state to Closed
Mar-01 10:28:03 AM
MyQ
Plugin detected device Sawgrass Garage Door changed state to Closing
Mar-01 10:27:22 AM
Mar-01 10:27:22 AM
Mar-01 10:24:01 AM
MyQ
Plugin detected device Sawgrass Garage Door changed state to Opened
Mar-01 10:23:52 AM
MyQ
Plugin detected device Sawgrass Garage Door changed state to Opening
Mar-01 10:22:19 AM
Mar-01 10:22:19 AM
Mar-01 10:17:16 AM
Mar-01 10:17:16 AM
Mar-01 10:15:00 AM
Log Info
The log database is currently 0.09MB in size.
Mar-01 10:12:13 AM
Mar-01 10:12:13 AM
Mar-01 10:07:10 AM
Mar-01 10:07:10 AM
Mar-01 10:02:06 AM
Mar-01 10:02:06 AM
Mar-01 9:57:03 AM
Mar-01 9:57:03 AM
Mar-01 9:52:00 AM
Mar-01 9:52:00 AM
Mar-01 9:46:57 AM
Mar-01 9:46:57 AM
Mar-01 9:41:54 AM
Mar-01 9:41:54 AM
Mar-01 9:36:51 AM
Mar-01 9:36:51 AM
Mar-01 9:31:47 AM
Mar-01 9:31:47 AM
Mar-01 9:26:44 AM
Mar-01 9:26:44 AM
Mar-01 9:21:41 AM
Mar-01 9:21:41 AM
Mar-01 9:16:38 AM
Mar-01 9:16:38 AM
Mar-01 9:11:35 AM
Mar-01 9:11:35 AM
Mar-01 9:06:32 AM
Mar-01 9:06:32 AM
Mar-01 9:06:00 AM
Energy DB Info
Mar-01 9:06:00 AM
Energy DB Info
Mar-01 9:06:00 AM
Energy DB Info
Mar-01 9:01:29 AM
Mar-01 9:01:29 AM
Mar-01 9:01:02 AM
Mar-01 9:01:01 AM
Device Control
Mar-01 9:00:59 AM
Device Control
Mar-01 9:00:55 AM
Mar-01 9:00:55 AM
Mar-01 9:00:52 AM
Device Control
Mar-01 8:56:16 AM
Mar-01 8:56:16 AM
Mar-01 8:55:47 AM
Mar-01 8:55:43 AM
Mar-01 8:55:43 AM
Mar-01 8:55:43 AM
Device Control
Mar-01 8:55:20 AM
Updater
An item in the Updater is temporarily unavailable: Error getting response stream (ReadDone2): ReceiveFailure Item: http://homeseer.du-pre.com/HS3/FritzBox3/updater.txt
Mar-01 8:55:12 AM
Plug-In
Mar-01 8:55:08 AM
Mar-01 8:55:08 AM
Upgrading from 1.2.0 to 1.2.1
Mar-01 8:55:08 AM
Info
Plugin Honeywell WiFi Thermostat has connected. IP:127.0.0.1:54200
Mar-01 8:54:16 AM
Updater
Install/Update of package Honeywell WiFi Thermostat failed.
Mar-01 8:54:16 AM
Updater Error
Installation of package Honeywell WiFi Thermostat failed. Try disabling the plugin first, then re-try the update.
Mar-01 8:54:15 AM
Updater
Extraction Complete.
Mar-01 8:54:15 AM
Updater
Extracting files from zip file: images.zip
Mar-01 8:54:15 AM
Updater
Copying file: \usr\local\HomeSeer\bin\skWare\WiFiThermostat\Newtonsoft.Jso n.dll
Mar-01 8:54:15 AM
Updater
Copying file: \usr\local\HomeSeer\HSPI_SKWARE_HW_WIFI_TSTAT.exe.config
Mar-01 8:54:15 AM
Updater
Mar-01 8:54:14 AM
Updater
Installing package Honeywell WiFi Thermostat
Mar-01 8:54:14 AM
Updater
Update HSPI_SKWARE_HW_WIFI_TSTAT.exe downloaded successfully
Mar-01 8:54:13 AM
Updater
Downloading update: Honeywell WiFi Thermostat
Mar-01 8:54:13 AM
Updater
Starting download of updates
Mar-01 8:53:43 AM
Updater
An item in the Updater is temporarily unavailable: The request timed out Item: http://home.indigozest.net/FTP/HomeS...UpdaterFTP.txt
Mar-01 8:53:32 AM
Updater
Mar-01 8:53:26 AM
Updater
Mar-01 8:35:12 AM
Info
Amazon Echo Discovery requested, version: 2
Mar-01 7:21:29 AM
Warning
File does not exist: /usr/local/HomeSeer/html/images/HAI/Unlocked_64.png
Mar-01 7:21:28 AM
Web Server
Web Server authorized local login successful from: 10.0.0.23 User: admin
Mar-01 7:19:31 AM
OMNI
Mar-01 7:19:31 AM
OMNI
Plugin startup is complete.
Mar-01 7:19:31 AM
OMNI
Mar-01 7:19:31 AM
OMNI
Synchronization complete.
Mar-01 7:16:43 AM
OMNI
Synchronizing OMNI devices with HomeSeer...
Mar-01 7:16:43 AM
OMNI
Requesting initial system troubles
Mar-01 7:16:37 AM
OMNI
Requesting Output status...
Mar-01 7:16:35 AM
OMNI
Requesting Area status...
Mar-01 7:16:35 AM
OMNI
All configuration and properties retrieved.
Mar-01 7:16:34 AM
OMNI
-->Reading properties...
Mar-01 7:15:49 AM
OMNI
-->Reading configuration...
Mar-01 7:15:47 AM
Info
System connected to MyHS Service successfully with license ID 98505.
Mar-01 7:15:47 AM
Startup
Start up complete.
Mar-01 7:15:47 AM
Info
Latest BETA update available is: 3.0.0.420
Mar-01 7:15:47 AM
Info
Latest update available is: 3.0.0.368
Mar-01 7:15:47 AM
Info
System connected to MyHS Service, waiting for acknowledge...
Mar-01 7:15:47 AM
TTS
Speak ():Welcome to Home-Seer
Mar-01 7:15:47 AM
Startup
Scripting is OK and is now running Startup.vb
Mar-01 7:15:47 AM
Info
Checking for updates...
Mar-01 7:15:47 AM
Startup
HSSentry is disabled in Setup, sentry will not be started.
Mar-01 7:15:47 AM
Startup
Starting Event Scheduler...
Mar-01 7:15:42 AM
Startup
Running the startup script Startup.vb
Mar-01 7:15:42 AM
Startup
Starting Find service...
Mar-01 7:15:42 AM
Startup
Updater services starting...
Mar-01 7:15:42 AM
Database
Opening (Mode=Read/Write) up HomeSeer Energy database /usr/local/HomeSeer/Data/Energy/Energy.hsd
Mar-01 7:15:42 AM
Speech
Listening for remote speaker connections on port 10401
Mar-01 7:15:42 AM
Startup
Initializing Speaker Client Interface
Mar-01 7:15:42 AM
Startup
Start automation engine...
Mar-01 7:15:42 AM
Web Server
UPNP Discovery started
Mar-01 7:15:42 AM
Web Server
Web Server started on port 80
Mar-01 7:15:42 AM
Web Server
Local IP address is: 10.0.0.19
Mar-01 7:15:41 AM
Startup
HStouch server started, waiting for clients to connect.
Mar-01 7:15:41 AM
HSTouch Server
Server started on port 10200
Mar-01 7:15:41 AM
Plug-In
Mar-01 7:15:41 AM
Error
Initializing plug-in(2): Honeywell WiFi Thermostat Instance::libcurlSTACK: Server stack trace: Exception rethrown at [0]: at (wrapper managed-to-native) System.Object:__icall_wrapper_mono_remoting_wrapper (intptr,intptr) at (wrapper remoting-invoke) HomeSeerAPI.IPlugInAPI:InitIO (string) at Scheduler.clsHSPI.CheckInterfaces () <0x7140c558 + 0x00217> in :0
Mar-01 7:15:40 AM
Mar-01 7:15:39 AM
Info
Plugin Honeywell WiFi Thermostat has connected. IP:127.0.0.1:54058
Mar-01 7:15:38 AM
Plug-In
Finished initializing plug-in OMNI
Mar-01 7:15:36 AM
Info
Plugin OMNI has connected. IP:127.0.0.1:54056
Mar-01 7:15:35 AM
Plug-In
Finished initializing plug-in MyQ
Mar-01 7:15:34 AM
MyQ
Initializing version 1.1.17344.311
Mar-01 7:15:34 AM
Info
Plugin MyQ has connected. IP:127.0.0.1:54054
Mar-01 6:17:21 AM
Startup
Initializing Plug-Ins
Mar-01 6:17:21 AM
Plug-In
Found plug-in: Z-Wave, version: 3.0.1.77
Mar-01 6:17:20 AM
Plug-In
Found plug-in: Honeywell WiFi Thermostat, version: 1.2.0.0
Mar-01 6:17:19 AM
Plug-In
Found plug-in: OMNI, version: 3.0.2.5
Mar-01 6:17:18 AM
Plug-In
Found plug-in: MyQ, version: 1.1.17344.311
Mar-01 6:17:17 AM
Database
Opening (Mode=Read/Write) up HomeSeer LOG database /tmp/HomeSeerLog.hsd
Mar-01 6:17:16 AM
Startup
Checking for available plug-ins
Mar-01 6:17:16 AM
Info
Remote plug-in API interface started on port 10400
Mar-01 6:17:16 AM
Startup
This version of HomeSeer is registered as a HS3ZEES2 version.
Mar-01 6:17:16 AM
Startup
Creating Speaker Client Interface Object...
Mar-01 6:17:16 AM
Startup
HomeSeer version is: 3.0.0.368
Mar-01 6:17:16 AM
Load Config
Loading TIMERS...
Mar-01 6:17:16 AM
Load Config
Loading COUNTERS...
Mar-01 6:17:16 AM
Load Config
11 total events loaded.
Mar-01 6:17:16 AM
Load Config
Loading Events...
Mar-01 6:17:16 AM
Load Config
Loading Event Groups...
Mar-01 6:17:16 AM
Load Config
115 total devices loaded.
Mar-01 6:17:16 AM
Database
Loading Devices...
Mar-01 6:17:15 AM
Database
Opening (Mode=Read Only) up HomeSeer database /usr/local/HomeSeer/Data/HomeSeerData.hsd
Mar-01 6:17:15 AM
Startup
Loading configuration file ...
Mar-01 6:17:15 AM
Startup
Database SAVE process started.
Mar-01 6:17:15 AM
Startup
Local voice recognition class started.
Mar-01 6:17:15 AM
Startup
Plug-In Interface class started.
Mar-01 6:17:15 AM
Startup
E-Mail RECEIVE class started.
Mar-01 6:17:15 AM
Startup
E-Mail SEND class started.
Mar-01 6:17:15 AM
Startup
Web server class started.
Mar-01 6:17:15 AM
Startup
Application interface class started.
Mar-01 6:17:15 AM
Startup
COM port classes started.
Mar-01 6:17:15 AM
Startup
Creating Class Objects...
Mar-01 6:17:15 AM
Startup
Mar-01 6:17:15 AM
Startup
Mar-01 6:17:15 AM
Startup
HomeSeer version 3.0.0.368 Edition: HS3 ZEE S2 Starting Now
Mar-01 6:17:15 AM
Startup
Mar-01 6:17:15 AM
Startup
Mar-01 6:17:13 AM
Startup
Settings Loaded.
Message/Source
Mar-01 2:38:21 PM
Mar-01 2:38:21 PM
Mar-01 2:33:18 PM
Mar-01 2:33:18 PM
Mar-01 2:32:43 PM
Updater
Mar-01 2:30:02 PM
Updater
Mar-01 2:28:15 PM
Mar-01 2:28:15 PM
Mar-01 2:27:46 PM
Mar-01 2:27:45 PM
Device Control
Mar-01 2:27:43 PM
Mar-01 2:27:43 PM
Mar-01 2:27:39 PM
Device Control
Mar-01 2:27:30 PM
Plug-In
Mar-01 2:27:25 PM
Mar-01 2:27:25 PM
Info
Mar-01 2:27:16 PM
Info
Mar-01 2:27:16 PM
Plug-In
Mar-01 2:24:15 PM
Mar-01 2:24:15 PM
Mar-01 2:23:46 PM
Mar-01 2:23:43 PM
Device Control
Mar-01 2:23:42 PM
Mar-01 2:23:42 PM
Mar-01 2:23:42 PM
Device Control
Mar-01 2:23:39 PM
Device Control
Mar-01 2:19:48 PM
Mar-01 2:19:48 PM
Mar-01 2:14:45 PM
Mar-01 2:14:45 PM
Mar-01 2:09:42 PM
Mar-01 2:09:42 PM
Mar-01 2:04:39 PM
Mar-01 2:04:39 PM
Mar-01 1:59:36 PM
Mar-01 1:59:36 PM
Mar-01 1:54:32 PM
Mar-01 1:54:32 PM
Mar-01 1:49:29 PM
Mar-01 1:49:29 PM
Mar-01 1:44:26 PM
Mar-01 1:44:26 PM
Mar-01 1:39:23 PM
Mar-01 1:39:23 PM
Mar-01 1:34:20 PM
Mar-01 1:34:20 PM
Mar-01 1:29:17 PM
Mar-01 1:29:17 PM
Mar-01 1:24:13 PM
Mar-01 1:24:13 PM
Mar-01 1:21:41 PM
MyQ Error
Mar-01 1:21:27 PM
MyQ Error
Mar-01 1:19:10 PM
Mar-01 1:19:10 PM
Mar-01 1:15:00 PM
Log Info
Mar-01 1:14:07 PM
Mar-01 1:14:07 PM
Mar-01 1:09:04 PM
Mar-01 1:09:04 PM
Mar-01 1:07:47 PM
Warning
Mar-01 1:06:00 PM
Energy DB Info
Mar-01 1:06:00 PM
Energy DB Info
Mar-01 1:06:00 PM
Energy DB Info
Mar-01 1:04:00 PM
Mar-01 1:04:00 PM
Mar-01 12:58:57 PM
Mar-01 12:58:57 PM
Mar-01 12:53:54 PM
Mar-01 12:53:54 PM
Mar-01 12:48:51 PM
Mar-01 12:48:51 PM
Mar-01 12:43:48 PM
Mar-01 12:43:48 PM
Mar-01 12:38:45 PM
Mar-01 12:38:45 PM
Mar-01 12:33:41 PM
Mar-01 12:33:41 PM
Mar-01 12:28:38 PM
Mar-01 12:28:38 PM
Mar-01 12:23:35 PM
Mar-01 12:23:35 PM
Mar-01 12:18:32 PM
Mar-01 12:18:32 PM
Mar-01 12:13:29 PM
Mar-01 12:13:29 PM
Mar-01 12:08:26 PM
Mar-01 12:08:26 PM
Mar-01 12:03:22 PM
Mar-01 12:03:22 PM
Mar-01 11:58:19 AM
Mar-01 11:58:19 AM
Mar-01 11:53:16 AM
Mar-01 11:53:16 AM
Mar-01 11:48:13 AM
Mar-01 11:48:13 AM
Mar-01 11:43:10 AM
Mar-01 11:43:10 AM
Mar-01 11:38:06 AM
Mar-01 11:38:06 AM
Mar-01 11:33:03 AM
Mar-01 11:33:03 AM
Mar-01 11:28:00 AM
Mar-01 11:28:00 AM
Mar-01 11:22:57 AM
Mar-01 11:22:57 AM
Mar-01 11:17:54 AM
Mar-01 11:17:54 AM
Mar-01 11:12:51 AM
Mar-01 11:12:51 AM
Mar-01 11:07:48 AM
Mar-01 11:07:48 AM
Mar-01 11:02:44 AM
Mar-01 11:02:44 AM
Mar-01 10:57:41 AM
Mar-01 10:57:41 AM
Mar-01 10:52:38 AM
Mar-01 10:52:38 AM
Mar-01 10:47:35 AM
Mar-01 10:47:35 AM
Mar-01 10:42:32 AM
Mar-01 10:42:32 AM
Mar-01 10:37:29 AM
Mar-01 10:37:29 AM
Mar-01 10:32:26 AM
Mar-01 10:32:25 AM
Mar-01 10:28:12 AM
MyQ
Mar-01 10:28:03 AM
MyQ
Mar-01 10:27:22 AM
Mar-01 10:27:22 AM
Mar-01 10:24:01 AM
MyQ
Mar-01 10:23:52 AM
MyQ
Mar-01 10:22:19 AM
Mar-01 10:22:19 AM
Mar-01 10:17:16 AM
Mar-01 10:17:16 AM
Mar-01 10:15:00 AM
Log Info
Mar-01 10:12:13 AM
Mar-01 10:12:13 AM
Mar-01 10:07:10 AM
Mar-01 10:07:10 AM
Mar-01 10:02:06 AM
Mar-01 10:02:06 AM
Mar-01 9:57:03 AM
Mar-01 9:57:03 AM
Mar-01 9:52:00 AM
Mar-01 9:52:00 AM
Mar-01 9:46:57 AM
Mar-01 9:46:57 AM
Mar-01 9:41:54 AM
Mar-01 9:41:54 AM
Mar-01 9:36:51 AM
Mar-01 9:36:51 AM
Mar-01 9:31:47 AM
Mar-01 9:31:47 AM
Mar-01 9:26:44 AM
Mar-01 9:26:44 AM
Mar-01 9:21:41 AM
Mar-01 9:21:41 AM
Mar-01 9:16:38 AM
Mar-01 9:16:38 AM
Mar-01 9:11:35 AM
Mar-01 9:11:35 AM
Mar-01 9:06:32 AM
Mar-01 9:06:32 AM
Mar-01 9:06:00 AM
Energy DB Info
Mar-01 9:06:00 AM
Energy DB Info
Mar-01 9:06:00 AM
Energy DB Info
Mar-01 9:01:29 AM
Mar-01 9:01:29 AM
Mar-01 9:01:02 AM
Mar-01 9:01:01 AM
Device Control
Mar-01 9:00:59 AM
Device Control
Mar-01 9:00:55 AM
Mar-01 9:00:55 AM
Mar-01 9:00:52 AM
Device Control
Mar-01 8:56:16 AM
Mar-01 8:56:16 AM
Mar-01 8:55:47 AM
Mar-01 8:55:43 AM
Mar-01 8:55:43 AM
Mar-01 8:55:43 AM
Device Control
Mar-01 8:55:20 AM
Updater
Mar-01 8:55:12 AM
Plug-In
Mar-01 8:55:08 AM
Mar-01 8:55:08 AM
Mar-01 8:55:08 AM
Info
Mar-01 8:54:16 AM
Updater
Mar-01 8:54:16 AM
Updater Error
Mar-01 8:54:15 AM
Updater
Mar-01 8:54:15 AM
Updater
Mar-01 8:54:15 AM
Updater
Mar-01 8:54:15 AM
Updater
Mar-01 8:54:15 AM
Updater
Mar-01 8:54:14 AM
Updater
Mar-01 8:54:14 AM
Updater
Mar-01 8:54:13 AM
Updater
Mar-01 8:54:13 AM
Updater
Mar-01 8:53:43 AM
Updater
Mar-01 8:53:32 AM
Updater
Mar-01 8:53:26 AM
Updater
Mar-01 8:35:12 AM
Info
Mar-01 7:21:29 AM
Warning
Mar-01 7:21:28 AM
Web Server
Mar-01 7:19:31 AM
OMNI
Mar-01 7:19:31 AM
OMNI
Mar-01 7:19:31 AM
OMNI
Mar-01 7:19:31 AM
OMNI
Mar-01 7:16:43 AM
OMNI
Mar-01 7:16:43 AM
OMNI
Mar-01 7:16:37 AM
OMNI
Mar-01 7:16:35 AM
OMNI
Mar-01 7:16:35 AM
OMNI
Mar-01 7:16:34 AM
OMNI
Mar-01 7:15:49 AM
OMNI
Mar-01 7:15:47 AM
Info
Mar-01 7:15:47 AM
Startup
Start up complete.
Mar-01 7:15:47 AM
Info
Mar-01 7:15:47 AM
Info
Mar-01 7:15:47 AM
Info
Mar-01 7:15:47 AM
TTS
Mar-01 7:15:47 AM
Startup
Mar-01 7:15:47 AM
Info
Mar-01 7:15:47 AM
Startup
Mar-01 7:15:47 AM
Startup
Mar-01 7:15:42 AM
Startup
Mar-01 7:15:42 AM
Startup
Mar-01 7:15:42 AM
Startup
Mar-01 7:15:42 AM
Database
Mar-01 7:15:42 AM
Speech
Mar-01 7:15:42 AM
Startup
Mar-01 7:15:42 AM
Startup
Mar-01 7:15:42 AM
Web Server
Mar-01 7:15:42 AM
Web Server
Mar-01 7:15:42 AM
Web Server
Mar-01 7:15:41 AM
Startup
Mar-01 7:15:41 AM
HSTouch Server
Mar-01 7:15:41 AM
Plug-In
Mar-01 7:15:41 AM
Error
Mar-01 7:15:40 AM
Mar-01 7:15:39 AM
Info
Mar-01 7:15:38 AM
Plug-In
Mar-01 7:15:36 AM
Info
Mar-01 7:15:35 AM
Plug-In
Mar-01 7:15:34 AM
MyQ
Mar-01 7:15:34 AM
Info
Mar-01 6:17:21 AM
Startup
Mar-01 6:17:21 AM
Plug-In
Mar-01 6:17:20 AM
Plug-In
Mar-01 6:17:19 AM
Plug-In
Mar-01 6:17:18 AM
Plug-In
Mar-01 6:17:17 AM
Database
Mar-01 6:17:16 AM
Startup
Mar-01 6:17:16 AM
Info
Mar-01 6:17:16 AM
Startup
Mar-01 6:17:16 AM
Startup
Mar-01 6:17:16 AM
Startup
Mar-01 6:17:16 AM
Load Config
Loading TIMERS...
Mar-01 6:17:16 AM
Load Config
Loading COUNTERS...
Mar-01 6:17:16 AM
Load Config
Mar-01 6:17:16 AM
Load Config
Loading Events...
Mar-01 6:17:16 AM
Load Config
Mar-01 6:17:16 AM
Load Config
Mar-01 6:17:16 AM
Database
Loading Devices...
Mar-01 6:17:15 AM
Database
Mar-01 6:17:15 AM
Startup
Mar-01 6:17:15 AM
Startup
Mar-01 6:17:15 AM
Startup
Mar-01 6:17:15 AM
Startup
Mar-01 6:17:15 AM
Startup
Mar-01 6:17:15 AM
Startup
Mar-01 6:17:15 AM
Startup
Mar-01 6:17:15 AM
Startup
Mar-01 6:17:15 AM
Startup
Mar-01 6:17:15 AM
Startup
Mar-01 6:17:15 AM
Startup
Mar-01 6:17:15 AM
Startup
Mar-01 6:17:15 AM
Startup
Mar-01 6:17:15 AM
Startup
Mar-01 6:17:15 AM
Startup
Mar-01 6:17:13 AM
Startup
Settings Loaded.
