Thermostat Status Failed
This topic is closed.
  • #16
    Originally posted by feobrien View Post
    Sorry if I am being dense here. But how do I actually execute those commands?
    You said it didn't help, so I'm a bit confused: did you attempt to execute them previously?
    Since the Zee is a linux box, the normal way to access a linux server is via an SSH client using the normal user credentials. However since I don't own a Zee I can't specifically tell you what that is... There's also a way to execute a system command from the menu, I believe.
    • #17
      Thanks to another Zee user, I have updated the commands needed if you're running this from the Tools > System Tools > Linux Commands feature of the HS3 Web UI. Please review this post for the details![/B]
      Once you've done that and updated the plugin (in either order) things should start working once you get a clean restart of the plugin. Thanks for your patience!
      • #18
        Finally got brave enough to execute all of the updated curl stuff and install the updated plug-in. I'm happy to say, all seems to be working well! I can once again connect to my thermostat. Thanks for all the advice and patience to get me through the updates
        • #19
          Unfortunately I spoke too soon. It worked for a while, now it has stopped. Shows "failed".
          • #20
            So it seems to work part of the time. Right now it shows everything fine, but earlier this morning, as well as a few times during the night, I see the following message in the log
            May-14 7:24:00 AM
            Honeywell WiFi Thermostat
            Failed to retrieve thermostat data - error occurred, will retry
            May-14 7:24:00 AM
            Curl command failed: Timeout was reached (28)
            • #21
              May-14 7:24:00 AM
              May-14 7:24:00 AM
              Ok, that's good news, actually. I intend to make the timeout setting configurable, I just didn't get to that change yet. I've got a bunch more stuff in the hopper to push out to update logging and provide some more control around the web requests, so I'll add this to it tonight.
              • #22
                It is working but log still shows some related error messages - today I see
                May-15 9:48:42 AM
                May-15 9:48:42 AM
                Error retrieving data for device 1434638: Unexpected character encountered while parsing value: <. Path '', line 0, position 0.
                May-15 9:43:38 AM
                • #23
                  Please see https://forums.homeseer.com/showthread.php?t=195799.
