Originally posted by amr42
View Post
Config page UI weirdness
Originally posted by shill View Post
I haven't started on it yet, so it will be a while.
Originally posted by shill View PostYour issue is pretty clearly called out in the log file: "The version of Mono on your system (4.6.2) is not supported."
Originally posted by shill View PostPlease see this sticky post: LINUX/ZEE USERS: MONO 4.8 OR HIGHER IS REQUIRED!!
Andrew
Originally posted by amr42 View Post
When will I be able to test the next version?
And, are these log entries related to this problem?Aug-26 9:06:25 PM Starting Plug-In Plugin Honeywell WiFi Thermostat started successfully in 1353 milliseconds Aug-26 9:06:24 PM Honeywell WiFi Thermostat [------]The version of Mono on your system (4.6.2) is not supported. Aug-26 9:06:24 PM Honeywell WiFi Thermostat [------]Running on Linux Version 4.9.0.7 using Mono version 4.6.2 Aug-26 9:06:24 PM Starting Plug-In Initializing plugin Honeywell WiFi Thermostat ... Aug-26 9:06:24 PM Honeywell WiFi Thermostat [------]Log file location: /usr/lib/HomeSeer/Logs/HSPI_SKWARE_HW_WIFI_TSTAT.log Aug-26 9:06:24 PM Info Plugin Honeywell WiFi Thermostat has connected. IP:127.0.0.1:37822 Aug-26 9:06:23 PM Plug-In Finished initializing plug-in Honeywell WiFi Thermostat
Please see the documentation on System Requirements (page 3) and/or this sticky post: LINUX/ZEE USERS: MONO 4.8 OR HIGHER IS REQUIRED!!
If this is your own Pi, you can use the process defined online to update Mono. If this is a HomeSeer-provided Pi (like the Zee S2), you'll need to contact HS for instructions on how to get a newer version.
Originally posted by shill View PostYeah, it doesn't do that on Windows... I found a solution for it, though, so the next version should correct that.
Fresh install of HS3 on Linux and now getting my thermostat plugin re-working...
The config page looks mighty weird at the bottom around the logging settings. See screenshot below. This is with Chrome browser on Windows 10.
Tags: None
