Shill
It looks like there is a software bug in vesion 1.3.2.0 of the Honeywell WiFi Thermostat plugin that causes an error when a thermostate is set to auto-switchover disabled..
Here's the scenario. I have two thermostats, Kitchen and Bedroom. Both have Min Cool: 72, Max Cool 99, Min Heat 40, Max Heat 76
Bedroom is configured to allow auto-switchover between Heat / Cool modes. HomeSeer shows a separate Heat Setpoint and a Cool Setpoint. This thermostat works fine on HomeSeer.
Kitchen, on the other hand, is configured so that auto switchover is disabled. HomeSeer shows a single setpoint. My expectation is that, in Heat Mode, you would use the single setpoint to select from the range 40-76, while in Cool Mode, you would that setpoint to select from 72-99. However, this Kitchen thermostat, when in Cool mode, only allows selection of 40-76 -- i.e., the same range as for Heating. It appears that, when a Thermostat with auto-switchover disabled is used, the plugin neglects to adjust the single setpoint's range depending on the mode and only uses the Heating mode's range. Can you take a look?
