What's the difference ??
  • What's the difference ??
    What's the difference between this plugin and your Lyric plugin ?
    It appears that it Lyric plugin is no longer supported ,, is that correct ??? Does this plugin replace the Lyric plugin seeing it is made by Honeywell ??
    TIA
    DEM
      This plugin is for the ones originally marketed as "wifithermostat.com" (hence the name) and controlled via the "Total Connect Comfort Portal". The Honeywell Lyric plugin is for the Lyric line (which use a totally different process and therefore aren't compatible with this plugin).
      Both are still supported.
        Do both require a cloud for operation remotely ??
          Yes.
