I have issues...and I need some help with the plugin also
Whenever I try to enable the plugin after installation it fails to start and gives "Critical. Plugin has disconnected." message. This is on a clean install Windows 10 machine version 1809 build 17763.194, fully updated with bare minimum applications installed (dedicated machine). The thermostat is a 7 Day Programmable RTH6580WF.
HS Setup:
Since I can't get it to start I don't have any thermostat log info, but the exception is being logged in Windows event application log. It's griping about mscorlib.ni.dll:
I also attached a report generated by this event:
I'm not sure what mscorlib.ni.dll's problem is. Ideas?
HS Setup:
Current Date/Time: 12/19/2018 2:06:24 PM HomeSeer Version: HS3 Standard Edition 3.0.0.435 Operating System: Microsoft Windows 10 Pro - Work Station System Uptime: 0 Days 0 Hours 24 Minutes 51 Seconds IP Address: 192.168.1.123 Number of Devices: 97 Number of Events: 12 Available Threads: 200 HSTouch Enabled: True Event Threads: 0 Event Trigger Eval Queue: 0 Event Trigger Priority Eval Queue: 0 Device Exec Queue: 0 HSTouch Event Queue: 0 Email Send Queue: 0 Anti Virus Installed: Windows Defender Enabled Plug-Ins 3.0.0.54: EasyTrigger 2.0.2.8: JowiHue 3.0.1.252: Z-Wave
Faulting application name: HSPI_SKWARE_HW_WIFI_TSTAT.exe, version: 1.4.0.0, time stamp: 0x5c0d6860 Faulting module name: mscorlib.ni.dll, version: 4.7.3260.0, time stamp: 0x5bb7bb40 Exception code: 0xc0000005 Fault offset: 0x004349b2 Faulting process id: 0x7a8 Faulting application start time: 0x01d497d29e887966 Faulting application path: C:\HS3\HSPI_SKWARE_HW_WIFI_TSTAT.exe Faulting module path: C:\Windows\assembly\NativeImages_v4.0.30319_32\mscorlib\6715dc4d04e35f16d482900c355325e9\mscorlib.ni.dll Report Id: f7ec1a8b-5639-48c8-91bf-64a3472df6ce Faulting package full name: Faulting package-relative application ID:
Fault bucket 1585454100594355593, type 5 Event Name: CLR20r3 Response: Not available Cab Id: 0 Problem signature: P1: HSPI_SKWARE_HW_WIFI_TSTAT.exe P2: 1.4.0.0 P3: 5c0d6860 P4: mscorlib P5: 4.7.3260.0 P6: 5bb7bb40 P7: 5b7f P8: 13 P9: System.NullReferenceException P10: Attached files: \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6C00.tmp.dmp \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6DC6.tmp.WERInternalMetadata.xml \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6DF6.tmp.xml \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6E23.tmp.csv \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6E81.tmp.txt These files may be available here: \\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_HSPI_SKWARE_HW_W_c53635dcf48deab8bc781846d68305ede9498ef_0eaea1c9_193172c6 Analysis symbol: Rechecking for solution: 0 Report Id: 0d2fa5c3-a201-446f-9ee5-b46c1defd052 Report Status: 268435456 Hashed bucket: b988bb77aac0bf449600aa1ab99ced89 Cab Guid: 0
