Changing setpoints in Auto mode
    I'm trying to create an event that changes the setpoints (cool/heat) when the thermostat is in Auto mode. However, using the "Honeywell WiFi Thermostat: Change Setpoint" action doesn't seem to show Auto as an option. When I originally installed the plug-in, I didn't have Auto enabled physically on the thermostat, so I was using "simulated auto mode" in the plug-in. Since then, I enabled Auto in the thermostat's installer options and turned off "simulated auto mode" in the plug-in.
    Should Auto appear as an option for this action? Or do I need to use "control a device" instead?
    heh, just had a hot day and the system was still in heat mode? same here.
      Another thing I thought of, maybe I need to set the Cool and Heat setpoints separately?
        Don't use the plugin-specific actions - I'm actually going to deprecate those in the HS4 version. Since you can control the thermostat using native HS device control actions, I decided there was no point in having a second way, and frankly programming for those event actions is a PITA...
          Ok, I'll try switching to the device actions instead of using the plug-in ones, thanks.
          How soon until the HS4 version is available?
