I'm trying to create an event that changes the setpoints (cool/heat) when the thermostat is in Auto mode. However, using the "Honeywell WiFi Thermostat: Change Setpoint" action doesn't seem to show Auto as an option. When I originally installed the plug-in, I didn't have Auto enabled physically on the thermostat, so I was using "simulated auto mode" in the plug-in. Since then, I enabled Auto in the thermostat's installer options and turned off "simulated auto mode" in the plug-in.
Should Auto appear as an option for this action? Or do I need to use "control a device" instead?
