INFO: Plugin start is pending for thermostat
    #16
    And yes, every homeseer plugin has a trial before you click purchase.
      #17
      Just uninstalled the plugin and deleted ini files. When I go to download the general version instead of the beta it poses another cost, which I am not willing to do. Why would I have to pay for another cost if I already did for the beta. As for the log file, when I click to downlaod I get the error file not found which is exactly the same for the documentation.
        #18
        Check your HS\logs directory, the file should be there
        The process of installing a plugin in homeseer doesn't cost money. Only registering it does. The fact it _shows_ you the cost is not the same as charging you. It's the same plugin.
          #19
          The files exceeds HS upload size. Also, I was charged 2 days ago when I downloaded the beta. Below is the post of the log for the 15th as the rest is trash.
          7/15/2022 20:22:08.464 Info Common.ClearLogFile - Log file cleared.
          7/15/2022 20:22:08.466 Trace Common.ClearLogFile - <<<< Common.ClearLogFile=True
          7/15/2022 20:22:08.467 Trace PluginOptionsPage.PostMessage - >>>> PluginOptionsPage.PostMessage()
          7/15/2022 20:22:08.468 Trace PluginOptionsPage.PostMessage - <<<< PluginOptionsPage.PostMessage
          7/15/2022 20:22:08.468 Debug PluginOptionsPage.postBackProc - Form postback processing complete.
          7/15/2022 20:22:08.469 Trace PluginOptionsPage.postBackProc - <<<< PluginOptionsPage.postBackProc=<html>
          7/15/2022 20:22:08.469 Trace HSPI.PostBackProc - <<<< HSPI.PostBackProc=<html>
          7/15/2022 20:22:14.212 Trace HSPI.PostBackProc - >>>> HSPI.PostBackProc(WiFi_Tstat_Configuration, &id=obtnDownload&btnDownload=Submit, kjcurtiss@bellsouth.net, 6)
          7/15/2022 20:22:14.212 Trace HSPI.SelectPage - >>>> HSPI.SelectPage(WiFi_Tstat_Configuration)
          7/15/2022 20:22:14.213 Trace HSPI.SelectPage - <<<< HSPI.SelectPage=<PluginOptionsPage>
          7/15/2022 20:22:14.213 Trace PluginOptionsPage.postBackProc - >>>> PluginOptionsPage.postBackProc(WiFi_Tstat_Configuration,&id= obtnDownload&btnDownload=Submit,kjcurtiss@bellsouth.net,6)
          7/15/2022 20:22:14.214 Debug PluginOptionsPage.postBackProc - Form field obtnDownload submitted on the Config page...
          7/15/2022 20:22:14.215 Trace PluginOptionsPage.PostMessage - >>>> PluginOptionsPage.PostMessage()
          7/15/2022 20:22:14.215 Trace PluginOptionsPage.PostMessage - <<<< PluginOptionsPage.PostMessage
          7/15/2022 20:22:14.220 Debug PluginOptionsPage.postBackProc - Form postback processing complete.
          7/15/2022 20:22:14.221 Trace PluginOptionsPage.postBackProc - <<<< PluginOptionsPage.postBackProc=<html>
          7/15/2022 20:22:14.222 Trace HSPI.PostBackProc - <<<< HSPI.PostBackProc=<html>
          7/15/2022 20:22:55.459 Trace HSPI.GetPagePlugin - >>>> HSPI.GetPagePlugin(WiFi_Tstat_Configuration, kjcurtiss@bellsouth.net, 6, )
          7/15/2022 20:22:55.461 Trace HSPI.SelectPage - >>>> HSPI.SelectPage(WiFi_Tstat_Configuration)
          7/15/2022 20:22:55.462 Trace HSPI.SelectPage - <<<< HSPI.SelectPage=<PluginOptionsPage>
          7/15/2022 20:22:55.462 Trace PluginOptionsPage.GetPagePlugin - >>>> PluginOptionsPage.GetPagePlugin(WiFi_Tstat_Configuration, kjcurtiss@bellsouth.net, 6, )
          7/15/2022 20:22:55.463 Debug PluginOptionsPage.GetPagePlugin - Building the Options page structure...
          7/15/2022 20:22:55.464 Trace PluginOptionsPage.BuildHeader - >>>> PluginOptionsPage.BuildHeader(False)
          7/15/2022 20:22:55.465 Trace PluginOptionsPage.BuildHeader - <<<< PluginOptionsPage.BuildHeader=<html>
          7/15/2022 20:22:55.466 Trace PluginOptionsPage.BuildContent - >>>> PluginOptionsPage.BuildContent()
          7/15/2022 20:22:55.467 Trace PluginOptionsPage.BuildCheckBox - >>>> PluginOptionsPage.BuildCheckBox(chkAccept, I accept the Terms & Conditions as outlined in the user documentation provided with this plugin.,True,False,False)
          7/15/2022 20:22:55.468 Trace PluginOptionsPage.BuildCheckBox - <<<< PluginOptionsPage.BuildCheckBox=<html>
          7/15/2022 20:22:55.469 Trace PluginOptionsPage.BuildTextBox - >>>> PluginOptionsPage.BuildTextBox(txtUser,,text,kjcurtiss@bells outh.net,35,False,False)
          7/15/2022 20:22:55.469 Trace PluginOptionsPage.BuildTextBox - <<<< PluginOptionsPage.BuildTextBox=<html>
          7/15/2022 20:22:55.471 Trace PluginOptionsPage.BuildTextBox - >>>> PluginOptionsPage.BuildTextBox(txtPassword,,password,ÖYUô°-îÌ
          Ñ ¥ûT2¯Gö^‹ù<»ÿMÛ–ö0ã"íz)ç[‚ï?Ì¿R“Ö«éÑ‘´x´Î
          }1ª©Ø~Š_Ý•šž•³qԍ¸H¼=ˆ Îy9ö6qUlœÕ¹
          RNh®
          L8,8­TÉ@yâ¼S‚¹¤Ù@¤<ˆ%BÎêèñesQËšœ|n.Ïfø'Cá*°G´Ç$}@J}eà÷âÔ^× #¾„ÓOï.kq¨éq¤Ká W(] ÔÀâClfh*`\'u>åLÆk{émsœ¬Lø-Ñcåõ‰ùߺó7†Ž®ÏŒKmŽ~UŠÂ gîUœï£×Ñ“<-þ7fTÆNfÏ ‚U~þ¥ËDõîšÞÖC†®¢¦ùû.(`^%*5‘³Z³!à³Ã99³ÌRóÏÜéÓ2d׿D#ÈØíw2¤5ÿ¯Å |èŽ
          ‡•ýFô¬»øqŧ±· i ©0q{“qÇ"M3‰1.O`ÕM¾ïcÛ²5Øî¹çµ£ ù^+yžœ+ ÌÂQí÷©U}{y_†[ÇweDÛ9êìíd`]&Bã͸y9Æ‚×K˜¥4o¨‰;©I‹´=jÖ
          ÍY•H8:u ÔKæ
          hì†Jœ©1AÎ2«k/1A„ cñá!6€M9:]-÷Þ±œ
          ¸Ñy©@ôDNÌsÂ6dÔr=œ‘cS´ö,•Íì… ëós$‘B‹ŠÝ›.nè!“1~ÏäÑä7ÝõíͶG”¼+ÇÏÖÎ
          záßp·+ÜæÏ1Úí£×lVBÁ—ný–¥!LQ`*Þdä‹;Z<CÓO>kÁTíÑ>u’.çAˆ¶±Ží~v6
          érùNðÌ9Û9Ì-Î’àŒð»¦\Vzôþ“mÇËÓâ›Öÿsj© 9ñS¼pgÍ
          ]-«ã¨Ðíš{ÿ(0ùq\ÀJ¸Äw©>¦YOS]Ÿ'·V²ÝÓˆK®¯[Úz©ë;qÞs\¶>IšŒÖŽœpˆS_h3ˆàc_ˆgh :°Â=0AR·‚œƒ4ÚTx&QòTEó5Ðfˆ{½{ÿ]ªQ!Sjãs§m²bb°û¯Œ¸¼òÚ.f®Èû·…WŠïÕGsT“³Üƒ7•ÎðÌÆùLñt]6ßʱ6è‘Ã0Kd‘ï—”0„ÀÇê‘n™¯aïds9Êgú—‘xœOQɯêÆ:|§^²<)²AÕÏ*#Õ­@vz X) ª¼Šæ°S'ƒw(©Ñv^:>#€Ì®?+"iXÜdXZI”(ÃM 䪪.R$…ÖjÔî ^-º],+¹ÏtSõÒ¬æ4›Õ¨Ò¨½ÔÁ©G‹¾îì´Ël¸óìäê“j™¶6Mé;
          WU/ˆ®ŸgÐØÃ¯^À ÅCùw?vƐÚÚ¨ÒÉîjíg÷¸=Ym4ä«è!¨¹=ƒ·P¥§¬­(­T 2¼×E<85ý³âþ ²–…·Ê„~½¿¢Ä³íâ®
          }â§«„IÍÜ3^Ìö™VÒ¥|»¢˜ªpä<y‹èWCýà@±´¥3¹Fpˆrù ·¿ôt.E¹O“³ðáüî¿h‡ežFÜÄ–FÙ6@¿ƒ%¼ØºÞ!lgVFû(ð"ØC!´
          ì­„o—Â"®éÅÝ’¦1¯ùôÙ<+-a+Þ#}+±&Ú¡üA³¹z°è ä½b•}~°ßˆÊ
          ~wZUâEª÷U=†ï,ÚH~IB
          µ*ò{‡˜{§åˆ)|xZÚ=Õ¾»0ÚٜӸT_ò9ªð®ñ,6U©eG.†ÉŠÐQ‘çqâBËò4½D¢n)à»[–n o8¨WrQÏýær}À±-–òy9ëŽ~·ç=…‘ª/ËlˆíC±¸Å„̆N9µÛÕ Óò4=¤ àô³ÇyÓ‚<Î ÖT¾X¯D3ƒ°¹3¹¡Ëð4+x^s¨©$Ú@q—j¨YÙ~ñ0yÖ8|΄nÂL|óߨ9Nö'ʹ¦ ` YÕo0ÇaZCÝ>h‘\ Gì‡ ¾À›jWˆ{]ðoÝx¸j‘™ø"Vª7c²ö©ˆ§¼z8ô¨®4Ɵ쇀?žêžØD>ÙÿÓ¾‹ÂnäÜ«¦—‚Zü@Õ, Ðî"­û.†°>áºGrñí§ G‘Ñ‚……aC‰è Xww6y²( „ëäJ{l⻞úÎ3ü¼®ÞÈn»CE·Î¸;;»©ê&áH9åŠíµšùœZé¥H52£¥ËÍ5Ö>2ô+„ÄŽ 9GÊoû' d/ͲþµT¿`ÖÒÒ1ó‰ÍSѤ•OãPü° wUÁnO«] éýø†ùÃtAº†=J6þã¶ìÖ$Ð-Ëy5á%
          ð³Ò]*™Øä¯Ò¶KnóÀ°ÖLJ~Š”`’.#
          ™.ÓÅi¤xž„
          À@É;%ÎD¯Ü‰3$Q˜´“ äù_ð…º¤jÞÿ3 <–i»@w˜/Y«MÎà˜×M Ù‰aõP‘3¼`Ž¯à¤­ªS°WŒQô‰8ýÝpu*ønÿÉ”…ô9þ¥÷b˜¾ÔC›eö÷ V©A«×ÚЗLv:þÄ_\Ü.Àâ޻ê@Ç]q…øLSÛ¹@ F¸ÿ E*š<®ËF£k12—/2mNÃÊÓhøÁ 4_{)Üüä‘Fù…â61*àê4yоÐIF3S\ûHJW{Q‘BŽ"PÞ«ƒÚR¢|ΐ"õ%8möa\锽lÛ I9lu$…¦M–Ÿc¨»Ð:Ô È…Üù;jUïR¬_î©„Ô¿
          èô¢ ㈗¹ ö¯“YÄÖ>Ä-r >6Ôî|ˆ"2÷µ$váÉ-LyhîÂ/Ïüˆ:WGŸË`͘:¥w߯Á¬øç
          ÕŽ™\da6“qS„âÊrjûç·Þœý¤“ µÌI|n
          打Î^ƒyÊ~^žBúÎâ½îj°¤˜…1ë ÇÌó\–ÆQ¿b\üv¼ÿ$fäUÿQÁRñ‡ÁWýb(Þ;‹‚5l÷ϳiƒoʉ‰Žd‘òÒ&ò¢5`'µÑˆ[MÝÔX¬yþå;ŠèîäÅ]‚dÚH¬GýÿŸØÀÏ'û—ÀùÕŸ¬>à=¢ÒG‚€‰Y»3<§[4TT Y`×ñóIÊ
          á5Hv<œ[ëgx¾¼ûÉgšü®knw—çÌ*›(˜¬P T>Xö:RjboÜžt7¥šeç`ò‚§HóPO¯ÇqMC5ÎË©Â:2Ï&á§²í §ÃãŽò,Žô!®¬ázbZ3pCÆ[JoÞgù丮v'
          @Z„\‹=ø®Ð c«*­3w{ÃâÂ’-:`퍇™sðw70Åßø…P£‘Ýû ` cø‘Ò‹é;ƒS˜¢3ûCs_“øvm·Rw[³«ÒíŠ¥[±ÒÉV`ü¢B¦Er?¤¿H?)¼st£{Ï#øÅx0Î¥®
          ÉFˆGýEŠ ð©µAÐFÓÊšØIB2;ýTÏñqx©
          >!ý‚rÉ«{‡Ž~#º¿&cÁ'–µGÊÅWëÓAWÅÎrn‹jOñòéŽízdã‹­t†ýÕìÈþÝÚûiÙ €Í NÐkòôW,ý²ÏU\襰›f,š3_wü‘_›à»üC|<*D¢©D?wãª*JÃw·q„š[›/Ù\•ž~+÷HæÓ¹*j ¥=×p6o¡ )'iú¸„µ™ù{{Õøë;»W:§3¢/U,ƒÖeȨhéy6ˆ"ÆÝl´ŸL]¤Slò~}Ÿeþ6 K×
          Ž˜ÓÐõÔµ»‚%p†þ’
          YZfˆŽ¬(í®TÊeêÔ¸¡}¼Å
          &óÃï ¯'¸™õÍ1—I˜"2kŽkaqmÖ>wa [9ú*UïP8<ÌØ<Bk DÆaX*5mKÜËWf 'ÓpíZþK lk–Ñ|Ö~ß÷K脼Þò¿tF1@Êí{õ~Ü6ÿ,Ý_*/ÑY2t0Ãw€ >¬“lòeý[rO§wÎHp ±÷47¸ø[Yÿ&¯5xK±²Îª?ºëP½}¥yJò_yz•çjsS¼Ùü7%ûû¯gÕô¸NÓã¬t¶¨p17í§Rq$q0 Ò 9
          ãÐt·½JÙ'ý}äå§XwÅý*üöðk
            #20
            That's just not how HS works... here's what it looks like to Add a new plugin:
            Click image for larger version  Name:	Picture1.png Views:	0 Size:	12.3 KB ID:	1557326
            Click image for larger version  Name:	Picture2.png Views:	0 Size:	31.2 KB ID:	1557327
            Once you install it, you'll see a message like this (I had to pick one I'd never used and one I don't plan on since this example just burned my free trial option... but I don't use Insteon):
            Click image for larger version  Name:	Picture3.png Views:	0 Size:	15.6 KB ID:	1557328
            Once you turn it on (with the slider on the bottom right) it starts up. Once your 30 days are up, you'll see something like this instead:
            Click image for larger version  Name:	Picture4.png Views:	0 Size:	16.4 KB ID:	1557329
            Only once you get to this point do you need to go to the store (the button when you "add" the plugin) and purchase, at which point you can "register" (the button once it's installed) using the credentials HS gives you.
            All of this is how EVERY (paid) plugin works with Homeseer and has nothing to do with any individual plugin.
              #21
              RNh®
              ÍY•H8:u ÔKæ
              ~wZUâEª÷U=†ï,ÚH~IB
              ™.ÓÅi¤xž„
              Ž˜ÓÐõÔµ»‚%p†þ’
              YZfˆŽ¬(í®TÊeêÔ¸¡}¼Å
              You're not kidding about it being trash... clearly something bad has happened on your machine; bad hard drive sector, corrupted memory, something not good. The log file is just written to with standard .NET file write commands, and obviously it's not supposed to look like that. Once you reinstall (either 1.4 or 3.1), I'd be very curious to know what your Homeseer html directory looks like (i.e. is there an "skWare\WiFiThermostat" folder) and keep an eye on the log file to see if it's continuing to contain gibberish.
                #22
                So after installing the original non beta program I have better results. Attached are the trace log, and a snipit of what the plugin says. Also this time the documentation was attached and I was able to print it out. I can't create a wifithermostat.com account as it
                  #23
                  I can't create a wifithermostat.com account as it continues to say your connection is not private. Is this the correct url?
                    #24
                    I have 3 thermostats in my house. I sent the snipit on only 1 of them but they are all the same. I can't control the up or down levels from the device, but when I go into the thermoss-4 picture I can control settings there. Should be able to make adjustment from the device thermos-3 picture. Also in thermos-3 the idle and on icons are not viewable. Seems I'm making progress but still something isn't correct. But it is much better progress than the beta that was loaded.
                      #25
                      Did you get past this? Because you wouldn't have any devices created at all if you didn't have an account. Nor would you be able to log in to the app if you didn't already have an account. But regardless of what you meant by this, the correctly Total Connect Comfort URL is: https://mytotalconnectcomfort.com/portal
                      "your connection is not private" means you're not using "https" in your browser.
                        #26
                        Looks like it worked this time based on your pictures! FWIW, I recommend always leaving the HS log at INFO and only set the plugin log at TRACE when you're troubleshooting. There are definite performance impacts from having either turned on, but you definitely don't want/need both.
                        And based on the log file you provided, it's successfully controlling things, too, so I'm not sure where you are with things right now:
                        7/16/2022 01:59:21.692 Trace [7194619] ThermostatCommand.Execute >>>> ThermostatCommand.Execute()
                        7/16/2022 01:59:21.692 Debug [7194619] ThermostatCommand.Execute Processing Setpoint command object
                        7/16/2022 01:59:21.692 Trace [7194619] HWConnection.SendChange >>>> HWConnection.SendChange(<objChange>)
                        7/16/2022 01:59:21.692 Debug [7194619] HWConnection.SendChange {"DeviceID":7194619,
                        "SystemSwitch":null,
                        "HeatSetpoint":null,
                        "CoolSetpoint":83.0,
                        "HeatNextPeriod":null,
                        "CoolNextPeriod":null,
                        "StatusHeat":1,
                        "StatusCool":1,
                        "FanMode":null}
                        7/16/2022 01:59:21.692 Trace [7194619] HWConnection.LoginIfNeeded >>>> HWConnection.LoginIfNeeded()
                        7/16/2022 01:59:21.692 Debug [7194619] HWConnection.LoginIfNeeded Last Login: 7/16/2022 01:58:28.401
                        7/16/2022 01:59:21.692 Trace [7194619] HWConnection.LoginIfNeeded <<<< HWConnection.LoginIfNeeded=1
                        7/16/2022 01:59:21.692 Trace [7194619] HWConnection.PerformRequest >>>> HWConnection.PerformRequest(SendChange , *<RequestParms>)
                        7/16/2022 01:59:21.692 Trace [7194619] HWConnection.GetHeaders >>>> HWConnection.GetHeaders(7194619, <RequestParameters>
                        7/16/2022 01:59:21.692 Trace [7194619] HWConnection.GetHeaders <<<< HWConnection.GetHeaders=User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/63.0.3239.132 Safari/537.36
                        Cache-Control: max-age=0
                        Host: mytotalconnectcomfort.com
                        Referer: https://mytotalconnectcomfort.com/po...ontrol/7194619
                        X-Requested-With: XMLHttpRequest
                        Content-Type: application/json; charset=UTF-8
                        7/16/2022 01:59:21.692 Debug [7194619] HWConnection.PerformRequest About to perform request for SendChange ...
                        7/16/2022 01:59:21.692 Debug [------] WebClientEx.GetWebRequest Getting WebRequest for 'https://mytotalconnectcomfort.com/portal/Device/SubmitControlScreenChanges'
                        7/16/2022 01:59:21.817 Debug [------] WebClientEx.GetWebResponse Getting response for 'https://mytotalconnectcomfort.com/portal/Device/SubmitControlScreenChanges'
                        7/16/2022 01:59:22.005 Debug [7194619] HWConnection.PerformRequest SendChange result = success
                        7/16/2022 01:59:22.021 Trace [7194619] HWConnection.PerformRequest <<<< HWConnection.PerformRequest=<Response>
                        7/16/2022 01:59:22.021 Trace [7194619] HWConnection.SendChange <<<< HWConnection.SendChange=True
                        7/16/2022 01:59:22.021 Debug [7194619] ThermostatCommand.Execute Successfully processed the Setpoint request
                        7/16/2022 01:59:22.021 Trace [7194619] ThermostatCommand.Execute <<<< ThermostatCommand.Execute
                          #27
                          I do have a mytotalconnectcomfort.com, but the document said to create a wifithermostat.com account. When that didn't work I just moved on entered my credentials for totalcomfort.com. I can't control the temp or heat by clicking the up or down arrows on the device dashboard. The only way I can control it is to go to root and it opens up to al the settings but why does kitchen have a red question mark and us UNKNOWN? Only here is where I can change the temperatures. So this doesn't pull the schedules from mytotalcomfort or do I have to create schedules. If this is all this is and no schedules, I'm having a hard time understanding for me the usage/benefit of having it.
                            #28
                            I guess they got rid of the old shortcut "WiFi thermostat.com" website; it used to just redirect you to their stupidly named total connect comfort site.
                            The reason for the unknown status on the root device is because HS changed the way things worked in HS4 and you're using an older HS3 plugin with HS4 (hence the new beta 3.1 version). You can just ignore that until you upgrade. Once I work out any remaining kinks with the beta and release it fully I'll wrap up the HS4 version.
                            As far as the control I'll have to look into that. Honestly I never use that view so it might be another thing that HS4 does differently and my HS3 plugin might need some updates
                            And no, it doesn't download the schedule, there no reason to duplicate that IMO, the scheduling works fine (though you can recreate it yourself in HS if you really want to). What HS control gives you is the ability to override the schedule based on occupancy, or change the setpoint temperature based on local conditions, or to lock out local change by kids by always resuming the schedule if the status is changed, or to let you trigger other events based on the temperature in the house, etc etc etc the list goes on...
                              #29
                              I don't use schedules on Honeywell's site or on the thermostat. I use Homeseer for everything, along with also changing the schedule/temp based on occupancy (example: I have a virtual device called "vacation mode" that, when turned on, enables my away lighting schedule, disables the thermostat schedules, etc.). I just find it easier to use HS4 as the central location to do all of this instead of Honeywell's stuff.
                              And if you don't want to see that red question mark, you can just hide that root device.
                                #30
                                I just tested this view on my own thermostat (I'm running the 3.1 beta) and it worked fine. I'll need you to clear the log file then go click one of the setpoint change arrows (just one of them, just once) then download the log file again so that it contains all the activity from you trying this. Also make sure you refresh the page after in case the issue is with homeseer not updating the device value.
