Apologies if this was covered elsewhere but a search did not yield an answer.
Plugin installed and registered thermostat simply and without issue on HS3. All thermostat attributes display correctly on web interface. I presumed the HSTouch Designer would see the thermostat as a device for, at a minimum, status tracking of temperature, but it does not. I did restart/refresh Designer after installing the plugin.
Am I missing something or is this functionality not there?
Thanks!
Thanks!
