Contacting HomeSeer This Week
See more
See less
Compatibility with Google Home (GH)
  • Compatibility with Google Home (GH)
    Nathan,
    Please refer to this post.
    Should your recommendations for the Echo be applied to Google Home?
    Edit - see this post also
    Thanks for the thread pointers Claude. I haven't tried Google Home yet. I'm guessing one is in my near future
    My sticky post on working with Amazon Echo has some good information about the device settings that are absolutely required to get HS3 and the echo working together. Most of the work to make my Insteon Thermostat plugin compatible with the echo was around understanding the HS3 virtual devices and then coming up with a naming scheme so the HS3 voice control worked.
    I would assume these same efforts need applied relative to making a plugin work with Google Home. I think that's what you are asking correct? If I've mis-understood please correct me. I may have to get a GH to see how compatible or not my plugin currently is with it.
    Nathan
    HS 3.0.0.435 (PRO)
    Hardware: Napco GEM-P9600 | VenstarT1800 w/Insteon 2441V adapter | Insteon PLM
    Plugins HS3: Napco Gemini (mine) | Insteon Thermostat (mine) | Insteon Plug-in (mnsandler) | HSTouch Server (HST)
    Platform: Windows 10 Pro 64bit, core2 duo 2.0Ghz, 4GB memory
    http://www.kazteel.com/
