I suspect that I have several incorrect links that were somehow added between my downstairs Insteon 2441TH Thermostat and a few of my Insteon switches. I notice that ceiling fans and some lights turn off when the HVAC for the downstairs comes on or shuts off and it's driving me nuts.
I went through and read the links from all the suspected switch devices using Mark's Insteon plugin, found a few links to the thermostat and deleted those but I am still having issues with 1 or 2 switches in my house.
My next step was to reset the thermostat back to factory settings and re-add it to the thermostat plugin but before I did that I wanted to make sure I carried these steps out correctly. Does the following look correct?
1. Delete the Thermostat from the plugin's configuration page using the 'Delete' button in the Actions section.
2. Press 'Save' on configuration page.
3. Perform the factory reset on the thermostat as defined in the user manual.
4. Add thermostat back to plugin, using the 'ADD NEW' Name field on Thermostat configuration page.
Is there anything else that I need to do to, de-register the thermostat from the HS system before the factory reset?
Do I need to manually delete any old devices of the thermostat before adding it back?
Other than reading and updating Links from the Thermostat, is there any way to Edit these links to simply delete bad ones to the switches in my house? This would save me the trouble of the whole factory reset I suppose. While I was able to read the links and copy the details from the Log, I can't make much sense of it and definitely did not see a way to edit or delete these links.
Thank you in advance for any help.
